Collisions on Feistel-MiMC and univariate GMiMC - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Xavier Bonnetain
  • Fonction : Auteur
  • PersonId : 1023884
MiMC and GMiMC are families of MPC-friendly block ciphers and hash functions. In this note, we show that the block ciphers MiMC-2n/n (or Feistel-MiMC) and univariate GMiMC are vulnerable to an attack which allows a key recovery in $2^{n/2}$ operations. This attack, which is reminiscent of a slide attack, only relies on their weak key schedules, and is independent of the round function ($x^3$ here) and the number of rounds.
mimc-collision.pdf (59.97 Ko) Télécharger le fichier
hal-02400343 , version 1 (09-12-2019)
  • HAL Id : hal-02400343 , version 1
Xavier Bonnetain. Collisions on Feistel-MiMC and univariate GMiMC. 2019. ⟨hal-02400343⟩
Collections
INRIA INRIA2
103 Consultations
142 Téléchargements
