Single molecule localization by $\ell_2-\ell_0$ constrained optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Single Molecule Localization Microscopy (SMLM) enables the acquisition of high-resolution images by alternating between activation of a sparse subset of fluorescent molecules present in a sample and localization. In this work, the localization problem is formulated as a constrained sparse approximation problem which is resolved by rewriting the $\ell_0$ pseudo-norm using an auxiliary term. In the preliminary experiments with the simulated ISBI datasets the algorithm yields as good results as the state-of-the-art in high-density molecule localization algorithms.
1812.05971.pdf (427.61 Ko) Télécharger le fichier
hal-02400407 , version 1 (09-12-2019)
Arne Bechensteen, Laure Blanc-Féraud, Gilles Aubert. Single molecule localization by $\ell_2-\ell_0$ constrained optimization. iTWIST'18, Nov 2018, Marseille, France. ⟨hal-02400407⟩
42 Consultations
41 Téléchargements
