H. Attouch, J. Bolte, P. Redont, and A. Soubeyran, Proximal alternating minimization and projection methods for nonconvex problems, An approach based on the Kurdyka-Lojasiewicz inequality, 2008.
A. Beck and M. Teboulle, A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, pp.183-202, 2009.
E. Betzig, G. H. Patterson, R. Sougrat, O. W. Lindwasser, S. Olenych et al., Imaging Intracellular Fluorescent Proteins at Nanometer Resolution. Science, vol.313, issue.5793, pp.1642-1645, 2006.
S. Gazagnes, E. Soubies, and L. Blanc-féraud, High density molecule localization for super-resolution microscopy using CEL0 based sparse approximation, 2017 IEEE 14th International Symposium on Biomedical Imaging (ISBI 2017), pp.28-31, 2017.
URL : https://hal.archives-ouvertes.fr/hal-01443565
S. T. Hess, T. P. Girirajan, and M. D. Mason, Ultra-High Resolution Imaging by Fluorescence Photoactivation Localization Microscopy, Biophysical Journal, vol.91, issue.11, pp.4258-4272, 2006.
M. J. Rust, M. Bates, and X. Zhuang, Sub-diffraction-limit imaging by stochastic optical reconstruction microscopy (STORM), Nature Methods, vol.3, issue.10, pp.793-796, 2006.
D. Sage, H. Kirshner, T. Pengo, N. Stuurman, J. Min et al., Quantitative evaluation of software packages for single-molecule localization microscopy, Nature Methods, vol.12, issue.8, pp.717-724, 2015.
E. Soubies, L. Blanc-féraud, and G. Aubert, A Unified View of Exact Continuous Penalties for l2-l0 Minimization, SIAM Journal on Optimization, vol.27, issue.3, 2017.
URL : https://hal.archives-ouvertes.fr/hal-01267701
C. Soussen, J. Idier, D. Brie, and J. Duan, From Bernoulli -Gaussian Deconvolution to Sparse Signal Restoration, IEEE Transactions on Signal Processing, vol.59, issue.10, pp.4572-4584, 2011.
URL : https://hal.archives-ouvertes.fr/hal-00443842
S. M. Stefanov, Convex quadratic minimization subject to a linear constraint and box constraints, Applied Mathematics Research eXpress, issue.1, pp.17-42, 2004.
G. Yuan and B. Ghanem, Sparsity Constrained Minimization via Mathematical Programming with Equilibrium Constraints
