Cyclides in pure blending i, Computer Aided Geometric Design, vol.14, issue.1, pp.51-75, 1997. ,
Segre symbols, 2016. ,
Circles on surfaces in the euclidean 3-space, Lecture Notes in Math, vol.792, pp.213-221, 1980. ,
Circular arc structures, vol.30, 2011. ,
Quadratic Forms and Their Classification by Means of Invariant-factors, TJ I'A. Bromwich, vol.3, 1906. ,
On cyclides and sphero-quartics, Philosophical Transactions of the Royal Society, vol.1870, issue.0, pp.585-721 ,
On the cyclide, Quart. J. of Pure and Appl. Math, vol.12, pp.148-165, 1873. ,
On variable radius blending using dupin cyclides, 1989. ,
, , 1916.
Sur le contact des courbes et des surfaces, Bulletin des Sciences Mathématiques et Astronomiques, vol.4, issue.1, pp.348-384, 1880. ,
Blending canal surfaces along given circles using dupin cyclides, International Journal of Computer Mathematics, vol.91, issue.3, pp.641-660, 2014. ,
Applications de géométrie et de méchanique, a la marine, aux ponts et chaussées, etc., pour faire suite aux Développements de géométrie, par Charles Dupin, p.1822 ,
Near-optimal parameterization of the intersection of quadrics, Proceedings of the nineteenth annual symposium on Computational geometry, pp.246-255, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00099789
Near-optimal parameterization of the intersection of quadrics: I. the generic algorithm, Journal of Symbolic Computation, vol.43, issue.3, pp.168-191, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00071229
Near-optimal parameterization of the intersection of quadrics: Ii. a classification of pencils, Journal of Symbolic Computation, vol.43, issue.3, pp.192-215, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00071228
Near-optimal parameterization of the intersection of quadrics: Iii. parameterizing singular intersections, Journal of Symbolic Computation, vol.43, issue.3, pp.216-232, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00071227
Dupin cyclide blends between quadric surfaces for shape modeling, Computer Graphics Forum, vol.23, pp.321-330, 2004. ,
Conversion of dupin cyclide patches into rational biquadratic bézier form, Lecture notes in computer science, vol.3604, pp.201-218, 2005. ,
, Cyclides and the guiding circle. Mathematics and Computers in Simulation, vol.73, issue.1, pp.168-174, 2006.
Continuous detection of the variations of the intersection curve of two moving quadrics in 3-dimensional projective space, Journal of Symbolic Computation, vol.73, pp.221-243, 2016. ,
Rational bézier formulas with quaternion and clifford algebra weights, SAGA-Advances in ShApes, Geometry, and Algebra, pp.147-166, 2014. ,
Ueber die flächen vierten grades, auf welchen schaaren von kegelschnitten liegen, Journal für die reine und angewandte Mathematik, vol.64, pp.66-76, 1865. ,
Intersecting quadrics: An efficient and exact implementation, Computational Geometry, vol.35, issue.1-2, pp.74-99, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00000380
A parametric algorithm for drawing pictures of solid objects composed of quadric surfaces, Communications of the ACM, vol.19, issue.10, pp.555-563, 1976. ,
Mathematical models for determining the intersections of quadric surfaces, Computer Graphics and Image Processing, vol.11, issue.1, pp.73-87, 1979. ,
, Families of circles on surfaces. Mathematics, 2013.
Prinicpal patches for computational geometry, 1982. ,
On the cyclide, Quart. J. of Pure and Appl. Math, vol.9, pp.111-126, 1868. ,
A method of generating surfaces as a composite of cyclide patches, The Computer Journal, vol.28, issue.4, pp.433-438, 1985. ,
Geometric algorithms for detecting and calculating all conic sections in the intersection of any 2 natural quadric surfaces, Graphical Models and Image Processing, vol.57, issue.1, pp.55-66, 1995. ,
On the computation of an arrangement of quadrics in 3d, Computational Geometry, vol.30, issue.2, pp.145-164, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00350858
Architectural geometry, vol.724, 2007. ,
Freeform surfaces from single curved panels, ACM Transactions on Graphics (TOG), vol.27, issue.3, p.76, 2008. ,
Darboux cyclides and webs from circles, Computer Aided Geometric Design, vol.29, issue.1, pp.77-97, 2012. ,
Cyclides in computer aided geometric design, Computer Aided Geometric Design, vol.7, issue.1, pp.221-242, 1990. ,
Cyclides in computer aided geometric design ii, Computer Aided Geometric Design, vol.12, issue.2, pp.131-152, 1995. ,
Studio sulle quadriche in uno spazio lineare ad un numero qualunque di dimensioni: memoria, 1884. ,
, Cyclides. Hokkaido Mathematical Journal, vol.29, issue.1, pp.119-148, 2000.
Using signature sequences to classify intersection curves of two quadrics, Computer Aided Geometric Design, vol.26, issue.3, pp.317-335, 2009. ,
Classifying the nonsingular intersection curve of two quadric surfaces, Geometric Modeling and Processing, pp.23-32, 2002. ,
A canonical form for a pair of real symmetric matrices that generate a nonsingular pencil, Linear Algebra and its Applications, vol.14, issue.3, pp.189-209, 1976. ,
Enhancing levin's method for computing quadric-surface intersections, Computer Aided Geometric Design, vol.20, issue.7, pp.401-422, 2003. ,
Computing quadric surface intersections based on an analysis of plane cubic curves, Graphical Models, vol.64, issue.6, pp.335-367, 2002. ,
Quadric-surface intersection curves: shape and structure, Computer-Aided Design, vol.25, issue.10, pp.633-643, 1993. ,
