Abstract : Deep Learning training memory needs can prevent
the user to consider large models and large batch
sizes. In this work, we propose to use techniques
from memory-aware scheduling and Automatic
Differentiation (AD) to execute a backpropagation
graph with a bounded memory requirement at the
cost of extra recomputations. The case of a single
homogeneous chain, i.e. the case of a network
whose all stages are identical and form a chain,
is well understood and optimal solutions have
been proposed in the AD literature. The networks
encountered in practice in the context of Deep
Learning are much more diverse, both in terms of
shape and heterogeneity.
In this work, we define the class of backpropagation
graphs, and extend those on which one can compute
in polynomial time a solution that minimizes the total
number of recomputations. In particular we consider
join graphs which correspond to models such as
Siamese or Cross Modal Networks.
