Human bony labyrinth dataset: Co-registered CT and micro-CT images, surface models and anatomical landmarks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Data in Brief Année : 2019
The presented data set consists of images, labels and surface models of 23 human bony labyrinths. For each specimen clinical computed tomography (CT) and co-registered high-resolution micro-CT images were acquired. Using the images, the bony labyrinth was segmented and 3D surface models were generated. Each specimen is accompanied by a description file containing the coordinates of anatomical landmarks and the corresponding cochlear coordinate system. The data set can be used to study the morphology of the inner ear or to evaluate segmentation algorithm as used for the preoperative planning of surgical procedures such as cochlear implantation.
hal-02402404 , version 1 (10-12-2019)
Wilhelm Wimmer, Lukas Anschuetz, Stefan Weder, Franca Wagner, Hervé Delingette, et al.. Human bony labyrinth dataset: Co-registered CT and micro-CT images, surface models and anatomical landmarks. Data in Brief, 2019, 27, pp.104782. ⟨10.1016/j.dib.2019.104782⟩. ⟨hal-02402404⟩
70 Consultations
0 Téléchargements
