, Pearson's Correlation Coefficient, 2008.
Variation Among Processors Under Turbo Boost in HPC Systems, 2016. ,
The NAS Parallel Bench-marks&Mdash, 1991. ,
Adding Virtualization Capabilities to the Grid'5000 Testbed, Cloud Computing and Services Science, vol.367, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00946971
Designing Reliable Systems from Unreliable Components: The Challenges of Transistor Variability and Degradation, IEEE Micro, vol.25, 2005. ,
Runtime-Guided Mitigation of Manufacturing Variability in Power-Constrained Multi-Socket NUMA Nodes, 2016. ,
Comparing Server Energy Use and Efficiency Using Small Sample Sizes, 2014. ,
The next 700 CPU power models, Journal of Systems and Software, vol.144, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01827132
How Does Docker Affect Energy Consumption? Evaluating Workloads in and out of Docker Containers. The journal of systems & Software, 2017. ,
The bootstrap and modern statistics, J. Amer. Statist. Assoc, vol.95, p.452, 2000. ,
Your Cluster Is Not Power Homogeneous: Take Care When Designing Green Schedulers!, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00870637
Noise-Tolerant Explicit Stencil Computations for Nonuniform Process Execution Rates, ACM Transactions on Parallel Computing, vol.2, issue.1, 2015. ,
Predicting the Performance and the Power Consumption of MPI Applications With SimGrid, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01446134
Analyzing and Mitigating the Impact of Manufacturing Variability in Power-Constrained Supercomputing, 2015. ,
Variations in CPU Power Consumption, 2016. ,
RAPL in Action: Experiences in Using RAPL for Power Measurements, ACM Trans. Model. Perform. Eval. Comput. Syst, vol.3, issue.9, 2018. ,
, Spectre Attacks: Exploiting Speculative Execution, 2019.
, Meltdown: Reading Kernel Memory from User Space, 2018.
An Empirical Survey of Performance and Energy Efficiency Variation on Intel Processors, 2017. ,
Resources Description, Selection, Reservation and Verification on a Largescale Testbed, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00965708
Effect of Meltdown and Spectre Patches on the Performance of HPC Applications, 2018. ,
Adaptive Body Bias for Reducing Impacts of Die-to-Die and within-Die Parameter Variations on Microprocessor Frequency and Leakage, IEEE Journal of Solid-State Circuits, vol.37, 2002. ,
Benchmarking Crimes: An Emerging Threat in Systems Security, 2018. ,
Energy Efficiency of Thermal-Aware Job Scheduling Algorithms under Various Cooling Models, Contemporary Computing, vol.40, 2009. ,
Worth their watts? -an empirical study of datacenter servers, 2010. ,
, Potential Effects on Server Power Metering and Modeling. Wireless Networks, 2018.
Experimental Characterization of Variation in Power Consumption for Processors of Different Generations ,
URL : https://hal.archives-ouvertes.fr/hal-02166019
