Modifications and clarifications for the implementation of the spalart-allmaras turbulence model, Seventh international conference on computational fluid dynamics (ICCFD7), pp.1-11, 2012. ,
Turbomachinery design by a swarm-based optimization method coupled with a cfd solver, Advances in aircraft and spacecraft science, vol.3, issue.2, pp.149-170, 2016. ,
Detailed numerical characterization of the separation-induced transition, including bursting, in a low-pressure turbine environment, 2013. ,
URL : https://hal.archives-ouvertes.fr/tel-00984351
Very high-order accurate discontinuous galerkin computation of transonic turbulent flows on aeronautical configurations, ADIGMA-A European Initiative on the Development of Adaptive Higher-Order Variational Methods for Aerospace Applications, pp.25-38, 2010. ,
On the flexibility of agglomeration based physical space discontinuous galerkin discretizations, Journal of Computational Physics, vol.231, issue.1, pp.45-65, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00562219
Prediction of separation-induced transition on high lift low pressure turbine blade, ASME 2011 Turbo Expo: Turbine Technical Conference and Exposition, pp.1835-1846, 2011. ,
Global and local pod models for the prediction of compressible flows with dg methods, International Journal for Numerical Methods in Engineering, vol.116, issue.5, pp.332-357, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01908303
Feedback filtering in discontinuous galerkin methods for euler equations. Progress in Computational Fluid Dynamics, an International Journal, vol.16, issue.1, pp.14-25, 2016. ,
Adaptive cfd schemes for aerospace propulsion, Journal of Physics: Conference Series, vol.841, issue.1, 2017. ,
Unstructured discretisation of a non-local transition model for turbomachinery flows, Advances in aircraft and spacecraft science, vol.4, pp.555-571, 2017. ,
A robust and adaptive recovery-based discontinuous galerkin method for the numerical solution of convection-diffusion equations, International Journal for Numerical Methods in Fluids, vol.77, issue.2, pp.63-91, 2015. ,
Gmsh: A 3-d finite element mesh generator with built-in pre-and post-processing facilities, International journal for numerical methods in engineering, vol.79, issue.11, pp.1309-1331, 2009. ,
Sharp interface approaches and deep learning techniques for multiphase flows, Journal of Computational Physics, vol.380, pp.442-463, 2018. ,
Dns and les of transitional flow around a high-lift turbine cascade at low reynolds number, 2nd International Workshop on High-Order CFD Methods, 2013. ,
Spanwise periodic dns/les of transitional turbine cascades, 5th International Workshop on High-Order CFD Methods, 2018. ,
Improving the rprop learning algorithm, Proceedings of the second international ICSC symposium on neural computation, pp.115-121, 2000. ,
Turbulence modeling in an immersed-boundary rans method, CTR Annual Briefs, pp.415-426, 2002. ,
Numerical investigations of separation-induced transition on high-lift lowpressure turbine using rans and les methods, Proceedings of the Institution of Mechanical Engineers, Part A: Journal of Power and Energy, vol.228, issue.8, pp.924-952, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01080267
Aerodynamic performance of a very high lift low pressure turbine airfoil (t106c) at low reynolds and high mach number with effect of free stream turbulence intensity, Journal of Turbomachinery, vol.134, issue.6, p.61009, 2012. ,
Advanced numerical setup for separation-induced transition on high-lift low-pressure turbine flows using the ?-r?tm odel, ASME Turbo Expo 2015: Turbine Technical Conference and Exposition, pp.2-39, 2015. ,
Physically constrained data-driven correction for reduced-order modeling of fluid flows, International Journal for Numerical Methods in Fluids, vol.89, issue.3, pp.103-122, 2019. ,
Implementation of a fast artificial neural network library (fann), 2003. ,
Calculation of high-lift cascades in low pressure turbine conditions using a three-equation model, Journal of Turbomachinery, vol.133, issue.3, p.31016, 2011. ,
A contribution to the numerical prediction of unsteady flows, AIAA journal, vol.22, issue.5, pp.602-610, 1984. ,
A paradigm for data-driven predictive modeling using field inversion and machine learning, Journal of Computational Physics, vol.305, pp.758-774, 2016. ,
Hidden physics models: Machine learning of nonlinear partial differential equations, Journal of Computational Physics, vol.357, pp.125-141, 2018. ,
Apparent transition behavior of widely-used turbulence models, International Journal of Heat and Fluid Flow, vol.28, issue.6, pp.1460-1471, 2007. ,
Machine-learning-augmented predictive modeling of turbulent separated flows over airfoils, AIAA Journal, pp.2215-2227, 2017. ,
Summary of the delft university wind turbine dedicated airfoils, Journal of solar energy engineering, vol.125, issue.4, pp.488-496, 2003. ,
A machine learning strategy to assist turbulence model development, 53rd AIAA Aerospace Sciences Meeting, p.1287, 2015. ,
Physics-informed machine learning approach for reconstructing reynolds stress modeling discrepancies based on dns data, Physical Review Fluids, vol.2, issue.3, p.34603, 2017. ,
