HiMod Reduction of Advection-Diffusion-Reaction Problems with General Boundary Conditions, Journal of Scientific Computing, vol.76, issue.1, pp.89-119, 2018. ,
Modifications and clarifications for the implementation of the Spalart-Allmaras turbulence model, Seventh international conference on computational fluid dynamics (ICCFD7, pp.1-11, 2012. ,
Turbomachinery design by a swarm-based optimization method coupled with a CFD solver, Advances in aircraft and spacecraft science, vol.3, issue.2, pp.149-170, 2016. ,
Interpolation method for adapting reducedorder models and application to aeroelasticity, AIAA journal, vol.46, issue.7, pp.1803-1813, 2008. ,
Design optimization using hyper-reduced-order models, Structural and Multidisciplinary Optimization, vol.51, issue.4, pp.919-940, 2015. ,
Data-driven methods in fluid dynamics: Sparse classification from experimental data, Whither Turbulence and Big Data in the 21st Century, pp.323-342, 2017. ,
A domain decomposition strategy for reduced order models. Application to the incompressible Navier-Stokes equations, Computer Methods in Applied Mechanics and Engineering, vol.267, pp.23-42, 2013. ,
Hi-POD solution of parametrized fluid dynamics problems: preliminary results, Model Reduction of Parametrized Systems, pp.235-254, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01479163
An 'empirical interpolation' method: application to efficient reduced-basis discretization of partial differential equations, Comptes Rendus Mathematique, vol.339, issue.9, pp.667-672, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00021702
Very high-order accurate discontinuous Galerkin computation of transonic turbulent flows on aeronautical configurations, ADIGMA-A European Initiative on the Development of Adaptive Higher-Order Variational Methods for Aerospace Applications, pp.25-38, 2010. ,
Time integration in the discontinuous galerkin code MIGALE-Unsteady problems, IDIHOM: Industrialization of High-Order Methods-A Top-Down Approach, pp.205-230, 2015. ,
On the flexibility of agglomeration based physical space discontinuous Galerkin discretizations, Journal of Computational Physics, vol.231, issue.1, pp.45-65, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00562219
A zonal Galerkin-free POD model for incompressible flows, Journal of Computational Physics, vol.352, pp.301-325, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01668546
Towards Real-time Vehicle Aerodynamic Design via Multi-fidelity Data-driven Reduced Order Modeling, 2018. ,
, Structural Dynamics, and Materials Conference, p.916
Iterative methods for model reduction by domain decomposition, Computers & Fluids, vol.38, issue.6, pp.1160-1167, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00193962
Nonlinear model reduction via discrete empirical interpolation, SIAM Journal on Scientific Computing, vol.32, issue.5, pp.2737-2764, 2010. ,
The proper generalized decomposition for advanced numerical simulations: a primer, 2013. ,
Global and local POD models for the prediction of compressible flows with DG methods, International Journal for Numerical Methods in Engineering, vol.116, issue.5, pp.332-357, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01908303
Feedback filtering in discontinuous Galerkin methods for Euler equations, an International Journal, vol.16, issue.1, pp.14-25, 2016. ,
Adaptive CFD schemes for aerospace propulsion, Journal of Physics: Conference Series, vol.841, issue.1, 2017. ,
Unstructured discretisation of a non-local transition model for turbomachinery flows, Advances in aircraft and spacecraft science, vol.4, issue.5, pp.555-571, 2017. ,
A robust and adaptive recovery-based discontinuous Galerkin method for the numerical solution of convectiondiffusion equations, International Journal for Numerical Methods in Fluids, vol.77, issue.2, pp.63-91, 2015. ,
Gmsh: A 3-D finite element mesh generator with built-in pre-and post-processing facilities, International journal for numerical methods in engineering, vol.79, issue.11, pp.1309-1331, 2009. ,
Sharp interface approaches and deep learning techniques for multiphase flows, Journal of Computational Physics, 2018. ,
PARALUTION project, 2014. ,
Aerodynamic performance of a very high lift low pressure turbine airfoil (T106C) at low Reynolds and high Mach number with effect of free stream turbulence intensity, Journal of Turbomachinery, vol.134, issue.6, p.61009, 2012. ,
Physically constrained data-driven correction for reduced-order modeling of fluid flows, International Journal for Numerical Methods in Fluids, 2018. ,
Recursive dynamic mode decomposition of transient and post-transient wake flows, Journal of Fluid Mechanics, vol.809, pp.843-872, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01856287
A contribution to the numerical prediction of unsteady flows, AIAA journal, vol.22, issue.5, pp.602-610, 1984. ,
Reduced order methods for modeling and computational reduction, vol.9, 2014. ,
Certified reduced basis approximation for parametrized partial differential equations and applications, Journal of Mathematics in Industry, vol.1, issue.1, p.3, 2011. ,
Free-form deformation, mesh morphing and reduced-order methods: enablers for efficient aerodynamic shape optimisation, International Journal of Computational Fluid Dynamics, vol.32, issue.4-5, pp.233-247, 2018. ,
Dynamic mode decomposition of numerical and experimental data, Journal of fluid mechanics, vol.656, pp.5-28, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01020654
Turbulence and the dynamics of coherent structures part I: coherent structures, Quarterly of applied mathematics, vol.45, issue.3, pp.561-571, 1987. ,
Projection-based model reduction: Formulations for physics-based machine learning, Computers & Fluids, 2018. ,
Dimension reduction in heterogeneous parametric spaces with application to naval engineering shape design problems, Advanced Modeling and Simulation in Engineering Sciences, vol.5, issue.1, p.25, 2018. ,
Feedback control by low-order modelling of the laminar flow past a bluff body, Journal of Fluid Mechanics, vol.634, pp.405-418, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00386355
