Abstract : Tests are getting the cornerstone of continuous development process and software evolution. Tests are the new gold. To improve test quality, a plethora of analyses is proposed such as test smells, mutation testing, test coverage. The problem is that each analysis often needs a particular way to expose its results to the developer. There is a need for an architecture supporting test running and analysis in a modular and extensible way. In this article we present an extensi-ble plugin-based architecture to run and report test results. DrTests is a new test browser that implements such plugin-based architecture. DrTests supports the execution of rotten tests, comments to tests, coverage and profiling tests.
