Parallel kinetic scheme in complex toroidal geometry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SMAI Journal of Computational Mathematics Année : 2022
We present an efficient solver for the conservative transport equation with variable coefficients in complex toroidal geometries. The solver is based on a kinetic formulation resembling the Lattice-Boltzmann approach. The chosen formalism allows to obtain an explicit and conservative scheme that requires no matrix inversion and whose CFL stability condition is independent from the poloidal dynamics. We present the method and its optimized parallel implementation on toroidal geometries. Two and three dimensional plasma physics test cases are carried out.
chukrut_paper_01_SMAI_JCM.pdf (4.15 Mo) Télécharger le fichier
hal-02404082 , version 1 (11-12-2019)
hal-02404082 , version 2 (17-01-2022)
Paternité
Matthieu Boileau, Bérenger Bramas, Emmanuel Franck, Romane Hélie, Philippe Helluy, et al.. Parallel kinetic scheme in complex toroidal geometry. SMAI Journal of Computational Mathematics, 2022, pp.249-271. ⟨10.5802/smai-jcm.86⟩. ⟨hal-02404082v2⟩
331 Consultations
178 Téléchargements
