Real-time fair resource allocation in distributed software defined networks, 29th International Teletraffic Congress (ITC 29), vol.1, pp.19-27, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01652533
Optimization flow control with newton-like algorithm, Telecommun. Syst, vol.15, issue.3-4, pp.345-358, 2000. ,
Variational Convergence for Functions and Operators, 1984. ,
An o(1/k) gradient method for network resource allocation problems, IEEE Transactions on Control of Network Systems, vol.1, issue.1, pp.64-73, 2014. ,
Nonlinear Programming, Athena Scientific, 1995. ,
A utility optimization approach to network cache design, IEEE INFOCOM 2016 -The 35th Annual IEEE International Conference on Computer Communications, pp.1-9, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01377841
Maximizing network utility of rechargeable sensor networks with spatiotemporally coupled constraints, IEEE Journal on Selected Areas in Communications, vol.34, issue.5, pp.1307-1319, 2016. ,
Centralized network utility maximization over aggregate flows, 14th International Symposium on Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks (WiOpt), pp.1-8, 2016. ,
Rate control for communication networks: shadow prices, proportional fairness and stability, Journal of the Operational Research Society, vol.49, issue.3, pp.237-252, 1998. ,
Optimization flow control. i. basic algorithm and convergence, IEEE/ACM Transactions on Networking, vol.7, issue.6, pp.861-874, 1999. ,
Fair end-to-end window-based congestion control, IEEE/ACM Trans. Netw, vol.8, issue.5, pp.556-567, 2000. ,
Approximate primal solutions and rate analysis for dual subgradient methods, SIAM Journal on Optimization, vol.19, issue.4, pp.1757-1780, 2009. ,
Energy optimal control for time-varying wireless networks, IEEE Transactions on Information Theory, vol.52, issue.7, pp.2915-2934, 2006. ,
Robust stochastic approximation approach to stochastic programming, SIAM Journal on Optimization, vol.19, issue.4, pp.1574-1609, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00976649
Problem Complexity and Method Efficiency in Optimization. A Wiley-Interscience publication, 1983. ,
A tutorial on decomposition methods for network utility maximization, IEEE Journal on Selected Areas in Communications, vol.24, issue.8, pp.1439-1451, 2006. ,
A unified framework for max-min and min-max fairness with applications, IEEE/ACM Trans. Netw, vol.15, issue.5, pp.1073-1083, 2007. ,
, Network optimization and control. Foundations and Trends R in Networking, vol.2, issue.3, pp.271-379, 2008.
Online learning and online convex optimization. Foundations and Trends in Machine Learning, vol.4, pp.107-194, 2011. ,
A distributed newton method for network utility maximization; part ii: Convergence, IEEE Transactions on Automatic Control, vol.58, issue.9, pp.2176-2188, 2013. ,
A simple parallel algorithm with an $o(1/t)$ convergence rate for general convex programs, SIAM Journal on Optimization, vol.27, issue.2, pp.759-783, 2017. ,
Accelerated backpressure algorithm, 2013 IEEE Global Communications Conference (GLOBECOM), pp.2269-2275, 2013. ,
