Forward-backward-forward methods with variance reduction for stochastic variational inequalities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
We develop a new stochastic algorithm with variance reduction for solving pseudo-monotone stochastic variational inequalities. Our method builds on Tseng's forward-backward-forward (FBF) algorithm, which is known in the deterministic literature to be a valuable alternative to Korpelevich's extragradient method when solving variational inequalities over a convex and closed set governed by pseudo-monotone, Lipschitz continuous operators. The main computational advantage of Tseng's algorithm is that it relies only on a single projection step and two independent queries of a stochastic oracle. Our algorithm incorporates a variance reduction mechanism and leads to almost sure (a.s.) convergence to an optimal solution. To the best of our knowledge, this is the first stochastic look-ahead algorithm achieving this by using only a single projection at each iteration.
SFBF.pdf (958.44 Ko) Télécharger le fichier
hal-02405776 , version 1 (11-12-2019)
hal-02405776 , version 2 (07-12-2020)
  • HAL Id : hal-02405776 , version 1
Radu Ioan Bot, Panayotis Mertikopoulos, Mathias Staudigl, Phan Tu Vuong. Forward-backward-forward methods with variance reduction for stochastic variational inequalities. 2019. ⟨hal-02405776v1⟩
161 Consultations
304 Téléchargements
