Compressive sensing: From theory to applications, a survey, Journal of Communications and Networks, vol.15, issue.5, pp.443-456, 2013. ,
, Sparsity-aware learning and compressed sensing: An overview
Theory and applications of compressed sensing, GAMM-Mitteilungen, vol.36, issue.1, pp.79-101, 2013. ,
Introduction to compressed sensing, Preprint, vol.93, issue.1, p.2, 2011. ,
A user's guide to compressed sensing for communications systems, IEICE Transactions on Communications, vol.96, issue.3, pp.685-712, 2013. ,
Bayesian compressive sensing for cluster structured sparse signals, Signal Processing, vol.92, issue.1, pp.259-269, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00636853
Model based bayesian compressive sensing via local beta process, Signal Processing, vol.108, issue.3, pp.259-271, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01094927
Compressed sensing, IEEE Transactions on Information Theory, vol.52, issue.4, pp.1289-1306, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00369486
On the role of sparse and redundant representations in image processing, Proceedings of the IEEE, vol.98, issue.6, pp.972-982, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00568893
A survey of sparse representation: algorithms and applications, IEEE Access, vol.3, pp.490-530, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01311245
Decoding by linear programming, IEEE Transactions on Information Theory, vol.51, issue.12, pp.4203-4215, 2005. ,
An iterative thresholding algorithm for linear inverse problems with a sparsity constraint, Communications on Pure and Applied Mathematics, vol.57, issue.11, pp.1413-1457, 2004. ,
Atomic decomposition by basis pursuit, SIAM Review, vol.43, issue.1, pp.129-159, 2001. ,
Regression shrinkage and selection via the lasso, Journal of the Royal Statistical Society. Series B (Methodological), pp.267-288, 1996. ,
Compressive radar imaging, 2007 IEEE Radar Conference, pp.128-133, 2007. ,
Robust face recognition via sparse representation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.31, issue.2, pp.210-227, 2009. ,
DOA estimation based on sparse signal recovery utilizing weighted l 1 -norm penalty, IEEE Signal Processing Letters, vol.19, issue.3, pp.155-158, 2012. ,
Sparse coding via thresholding and local competition in neural circuits, Neural Computation, vol.20, issue.10, pp.2526-2563, 2008. ,
Convergence and rate analysis of neural networks for sparse approximation, IEEE Transactions on Neural Networks and Learning Systems, vol.23, issue.9, pp.1377-1389, 2012. ,
Discrete and continuous-time softthresholding for dynamic signal recovery, IEEE Transactions on Signal Processing, vol.63, issue.12, pp.3165-3176, 2015. ,
Correction to "Convergence and Rate Analysis of Neural Networks for Sparse Approximation, IEEE Transactions on Neural Networks and Learning Systems, vol.25, issue.8, pp.1595-1596, 2014. ,
Dynamical sparse recovery with finite-time convergence, IEEE Transactions on Signal Processing, vol.65, issue.23, pp.6146-6157, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01649419
Finite-time stability of continuous autonomous systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
Finite time stability and robust control synthesis of uncertain switched systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2004. ,
Nonlinear feedback design for fixed-time stabilization of linear control systems, IEEE Transactions on Automatic Control, vol.57, issue.8, pp.2106-2110, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00757561
A note on finite-time and fixed-time stability, Neural Networks, vol.81, pp.11-15, 2016. ,
A new class of finite-time nonlinear consensus protocols for multiagent systems, International Journal of Control, vol.87, issue.2, pp.363-370, 2014. ,
On sparse representations in arbitrary redundant bases, IEEE Transactions on Information Theory, vol.50, issue.6, pp.1341-1344, 2004. ,
, Noninear systems, vol.2, pp.5-6, 1996.
Distributed robust finite-time nonlinear consensus protocols for multi-agent systems, International Journal of Systems Science, vol.47, issue.6, pp.1366-1375, 2016. ,
