New interface
Journal articles
Algorithm to compute nonlinear partial observer normal form with multiple outputs
Abstract : It is well-known that observer design is a powerful tool to estimate the states of a dynamical system. Given a multi-output nonlinear dynamical system whose states are partially observable, this paper investigates the problem of observer design to estimate those observable states. It considers firstly a nonlinear system without inputs, and provides a set of geometric conditions, guaranteeing the existence of a change of coordinates which splits the studied nonlinear dynamical system into two subsystems, where one of them is of the well-known nonlinear observer normal form, for which a Luenberger-like observer can be designed. An extension to nonlinear systems with inputs has then been deduced.
Document type :
Journal articles
Complete list of metadata
Cited literature [35 references]  Display  Hide  Download
https://hal.inria.fr/hal-02406825
Contributor : Gang Zheng Connect in order to contact the contributor
Submitted on : Thursday, December 12, 2019 - 11:39:45 AM
Last modification on : Tuesday, November 22, 2022 - 2:26:16 PM
Long-term archiving on: : Friday, March 13, 2020 - 9:36:10 PM
File
tacfinal2.pdf
Identifiers
Citation
Wided Saadi, Driss Boutat, Gang Zheng, Lassaad Sbita, Lei Yu. Algorithm to compute nonlinear partial observer normal form with multiple outputs. IEEE Transactions on Automatic Control, 2020, 65 (6), pp.2700 - 2707. ⟨10.1109/TAC.2019.2946528⟩. ⟨hal-02406825⟩
Share
Metrics
Record views
68
Files downloads
232
