HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Closed-loop control of soft robot based on machine learning
Abstract : In this paper, we present a new strategy to control the soft robot with elastic behavior, piloted by 4 actuators. The main contribution of this work is the use of neural network to get approximated model soft robots, based on which a robust controller is then proposed. In this paper, we proved that if the approximated model satisfies certain conditions, then the proposed robust controller can always drive any given point of interest of the robot to the desired position, without knowing the exact model. Finally, the proposed result is experimented and validated by a 3D printed silicone soft robot.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-02406854
Contributor : Gang Zheng Connect in order to contact the contributor
Submitted on : Thursday, December 12, 2019 - 11:48:39 AM
Last modification on : Thursday, March 24, 2022 - 3:43:40 AM
Identifiers
Citation
Yuan Zhou, Mingda Ju, Gang Zheng. Closed-loop control of soft robot based on machine learning. CCC 2019 - 38th Chinese Control Conference, Jul 2019, Guangzhou, China. pp.4543-4547, ⟨10.23919/ChiCC.2019.8866257⟩. ⟨hal-02406854⟩
Share
Metrics
Record views
54
