Abstract : Motivations Short-read accuracy is important for downstream analyses such as genome assembly and hybrid long-read correction. Despite much work on short-read correction, present-day correctors either do not scale well on large data sets or consider reads as mere suites of k-mers, without taking into account their full-length read information. Results We propose a new method to correct short reads using de Bruijn graphs, and implement it as a tool called Bcool. As a first step, Bcool constructs a compacted de Bruijn graph from the reads. This graph is filtered on the basis of k-mer abundance then of unitig abundance, thereby removing from most sequencing errors. The cleaned graph is then used as a reference on which the reads are mapped to correct them. We show that this approach yields more accurate reads than k-mer-spectrum correctors while being scalable to human-size genomic datasets and beyond. Availability and Implementation
https://hal.inria.fr/hal-02407243
Contributor : Pierre Peterlongo <>
Submitted on : Thursday, December 12, 2019 - 2:06:41 PM Last modification on : Friday, January 8, 2021 - 3:39:48 AM Long-term archiving on: : Friday, March 13, 2020 - 9:50:02 PM
Antoine Limasset, Jean-François Flot, Pierre Peterlongo. Toward perfect reads: self-correction of short reads via mapping on de Bruijn graphs. Bioinformatics, Oxford University Press (OUP), 2019, ⟨10.1093/bioinformatics/btz102⟩. ⟨hal-02407243⟩
