Requirements for a Lightweight AKE for OSCORE
This document compiles the requirements for a lightweight authenticated key exchange protocol for OSCORE. This draft has completed a working group last call (WGLC) in the LAKE working group. Post-WGLC, the requirements are considered sufficiently stable for the working group to proceed with its work. It is not currently planned to publish this draft as an RFC.
