Necessar(il)y Evil dealing with benchmarks, ugh, 2013. ,
Conversion of Control Dependence to Data Dependence, Proceedings of the 10th ACM SIGACT-SIGPLAN Symposium on Principles of Programming Languages, POPL '83, pp.177-189, 1983. ,
PetaBricks: a language and compiler for algorithmic choice, ACM Conference on Programming Language Design and Implementation (PLDI), 2009. ,
Energy parsimonious circuit design through probabilistic pruning, Design, Automation and Test in Europe (DATE), 2011. ,
Green: A framework for supporting energy-conscious programming using controlled approximation, ACM Conference on Programming Language Design and Implementation (PLDI), 2010. ,
Uncer-tain\textlessT\textgreater: A First-Order Type for Uncertain Data, International Conference on Architectural Support for Programming Languages and Operating Systems (ASPLOS), 2014. ,
JSyn -A Real-time Synthesis API for Java, Proceedings of the International Computer Music Conference, pp.252-255, 1998. ,
Verifying Quantitative Reliability for Programs that Execute on Unreliable Hardware, ACM Conference on Object-Oriented Programming, Systems, Languages, and Applications (OOPSLA), 2013. ,
A Priority-Based 6t/8t Hybrid SRAM Architecture for Aggressive Voltage Scaling in Video Applications, IEEE Transactions on Circuits and Systems for Video Technology, vol.21, pp.101-112, 2011. ,
Global Code Motion/Global Value Numbering, Proceedings of the ACM SIGPLAN 1995 Conference on Programming Language Design and Implementation, PLDI '95, pp.246-257, 1995. ,
A Simple Graph-based Intermediate Representation, Papers from the 1995 ACM SIGPLAN Workshop on Intermediate Representations, IR '95, pp.35-49, 1995. ,
The Program Dependence Graph and Its Use in Optimization, ACM Trans. Program. Lang. Syst, vol.9, issue.3, pp.319-349, 1987. ,
IM-PACT: Imprecise adders for low-power approximate computing, International Symposium on Low Power Electronics and Design (ISLPED), 2011. ,
Smile -Statistical Machine Intelligence and Learning Engine, 2017. ,
OpenIMAJ and Im-ageTerrier: Java libraries and tools for scalable multimedia analysis and indexing of images, Proceedings of the 19th ACM international conference on Multimedia, MM '11, pp.691-694, 2011. ,
The Elements of Statistical Learning -Data Mining ,
Mitigating the Compiler Optimization Phase-ordering Problem Using Machine Learning, Proceedings of the ACM International Conference on Object Oriented Programming Systems Languages and Applications, OOPSLA '12, pp.147-162, 2012. ,
SRAM supply voltage scaling: A reliability perspective, International Symposium on Quality Electronic Design, 2009. ,
Data-Oriented Characterization of Application-Level Energy Optimization, 2015. ,
Compressive Network Coding for Approximate Sensor Data Gathering, IEEE Global Communications Conference (GLOBECOM), 2011. ,
EMEURO: A Framework for Generating Multi-purpose Accelerators via Deep Learning, International Symposium on Code Generation and Optimization (CGO), 2015. ,
, Lucene in Action, 2010.
Chisel: Reliability-and Accuracy-aware Optimization of Approximate Computational Kernels, ACM Conference on Object-Oriented Programming, Systems, Languages, and Applications (OOPSLA), 2014. ,
Parallelizing Sequential Programs With Statistical Accuracy Tests, 2010. ,
A Survey of Techniques for Approximate Computing, ACM Comput. Surv, vol.48, issue.4, 2016. ,
FlexJava: Language Support for Safe and Modular Approximate Programming, Proceedings of the 2015 10th Joint Meeting on Foundations of Software Engineering, ESEC/FSE 2015, pp.745-757, 2015. ,
ASLAN: Synthesis of Approximate Sequential Circuits, Design, Automation and Test in Europe (DATE), 2014. ,
Paraprox: Patternbased Approximation for Data Parallel Applications, International Conference on Architectural Support for Programming Languages and Operating Systems (ASPLOS), 2014. ,
Approximate Computing: An Annotated Bibliography, 2016. ,
EnerJ: approximate data types for safe and general lowpower computation, ACM Conference on Programming Language Design and Implementation (PLDI), 2011. ,
Stochastic Optimization of Floating-Point Programs with Tunable Precision, ACM Conference on Programming Language Design and Implementation (PLDI), 2014. ,
Design and implementation of an "approximate" communication system for wireless media applications, ACM SIGCOMM, 2010. ,
A Low Latency Generic Accuracy Configurable Adder, Design Automation Conference (DAC), 2015. ,
Managing Performance vs. Accuracy Trade-offs with Loop Perforation, Proceedings of the 19th ACM SIGSOFT Symposium and the 13th ,
, European Conference on Foundations of Software Engineering, ESEC/FSE '11, pp.124-134, 2011.
Approximating Outside the Processor, 2015. ,
Lax: Driver Interfaces for Approximate Sensor Device Access, USENIX Workshop on Hot Topics in Operating Systems (HotOS), 2015. ,
Reducing power by optimizing the necessary precision/range of floating-point arithmetic, IEEE Transactions on Very Large Scale Integration (VLSI) Systems, vol.8, issue.3, 2000. ,
Substitute-andsimplify: A Unified Design Paradigm for Approximate and Quality Configurable Circuits, Design, Automation and Test in Europe (DATE), 2013. ,
SSA-based reduction of operator strength. Thesis, 1994. ,
Approximate Computing: A Survey, IEEE Design Test, vol.33, issue.1, pp.8-22, 2016. ,
Estimating perceptual audio system quality using PEAQ algorithm, 2005. ,
