Finite Volume Method for a System of Continuity Equations Driven by Nonlocal Interactions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a new finite volume method for computing numerical approximations of a system of nonlocal transport equation modeling interacting species. This method is based on the work [F. Delarue, F. Lagoutire, N. Vauchelet, Convergence analysis of upwind type schemes for the aggregation equation with pointy potential, Ann. Henri. Lebesgue 2019], where the nonlocal continuity equations are 10 treated as conservative transport equations with a nonlocal, nonlinear, rough velocity field. We analyze some properties of the method, and illustrate the results with numerical simulations.
ElKeurtiRey_FVCA9.pdf (349.35 Ko) Télécharger le fichier
hal-02408246 , version 1 (13-12-2019)
Paternité - Pas d'utilisation commerciale - Partage selon les Conditions Initiales
Anissa El Keurti, Thomas Rey. Finite Volume Method for a System of Continuity Equations Driven by Nonlocal Interactions. International Conference on Finite Volumes for Complex Applications, Jun 2020, Bergen, Norway. ⟨10.1007/978-3-030-43651-3_20⟩. ⟨hal-02408246⟩
133 Consultations
194 Téléchargements
