Hybrid Reynolds-Averaged Navier-Stokes/Large-Eddy Simulation Models for Flow Around an Iced Wing, Journal of Aircraft, vol.52, issue.1, pp.244-256, 2015. ,
Eddy Structure Identification, International Center for Mechanical Sciences, 1996. ,
Improved Delayed Detached-Eddy Simulation on a Swept Hybrid Model in IRT, 2016. ,
A general classification of three dimensional flow field, Physics of Fluids A: Fluid Dynamics, vol.2, 1990. ,
Recent improvements in the Zonal Detached Eddy Simulation (ZDES) formulation. Theoretical and Computational Fluid Dynamics, vol.26, pp.523-550, 2011. ,
Detached-Eddy Simulation of the F-15E at High Alpha, Journal of Aircraft, vol.41, issue.2, pp.193-200, 2004. ,
Prediction of Performance Degradation due to Icing for 2D Configurations (AG-32). Retrieved from Holmén, 2003. ,
IDDES simulation of flow separation on an 3-D NACA23012 airfoil with spanwise ridge ice, 2018. ,
Studying Turbulence Using Numerical Simulation Databases, 2. Proceedings of the, vol.11, 1988. ,
Detached-eddy simulation of wing-tip vortex in the near field of NACA 0015 airfoil, Journal of Hydrodynamics, vol.26, issue.2, pp.60022-60028, 2014. ,
DES/DDES post-stall study with iced airfoil, 2011. ,
A comprehensive study of detached-eddy simulation. (Doctor Engineer Dissertation), 2009. ,
An Overview Of DDES In SU2, 2017. ,
Hybrid rans/les calculations in su2, 2017. ,
Ice accretion on a NACA 23012 airfoil, 2018. ,
, DETACHED EDDY SIMULATIONS FOR AIRFOIL WITH ICE SHAPES. Paper presented at the 42nd AIAA Aerospace Sciences Meeting and Exhibit, 2004.
Detached Eddy Simulations for Iced Airfoils, Journal of Aircraft, vol.42, issue.6, pp.1452-1461, 2005. ,
An Enhanced Version of DES with Rapid Transition from RANS to, LES in Separated Flows. Flow, Turbulence and Combustion, vol.95, issue.4, pp.709-737, 2015. ,
Strategies for turbulence modelling and simulations, International Journal of Heat and Fluid Flow, vol.21, pp.252-263, 2000. ,
A one-equation turbulence model for aerodynamic flows, 1992. ,
A One-Equation Turbulence Model for Aerodynamic Flows, Recherche Aérospatiale, vol.1, pp.5-21, 1994. ,
, Comments on the feasibility of LES for wings, and on a hybrid RANS/LES approach. Paper presented at the Advances in DNS/LES First AFOSR International Conference on DNS/LES, Lousinia, 1997.
Comments on the feasibility of LES for wings, and on a hybrid RANS/LES approach, Advances in DNS/LES, vol.1, 1997. ,
A New Version of Detached-eddy Simulation, Resistant to Ambiguous Grid Densities, Theoretical and Computational Fluid Dynamics, vol.20, issue.3, pp.181-195, 2006. ,
CFD study of airfoil lift reduction caused by ice roughness, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01963717
, Viscous fluid flow, 2006.
Numerical Study of an Iced Airfoil Using Window-Embedded RANS/LES Hybrid Method, 2017. ,
Zonal Detached-Eddy Simulation of Turbulent Unsteady Flow over Iced Airfoils, Journal of Aircraft, vol.53, issue.1, pp.168-181, 2016. ,
