Ice Shape Scaling for Aircraft in SLD Conditions, 2008. ,
Improved heat transfer predictions on rough surfaces, International Journal of Heat and Fluid Flow, vol.56, pp.160-171, 2015. ,
Development of a second generation in-flight icing simulation code, Journal of Fluids Engineering, vol.128, issue.2, pp.378-387, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00337571
Development of a Shallow-Water Icing Model in FENSAP-ICE, Journal of Aircraft, vol.37, issue.4, pp.640-646, 2000. ,
Iced-airfoil aerodynamics, Progress in Aerospace Sciences, vol.41, issue.5, pp.323-362, 2005. ,
A robust coupling algorithm applied to thermal ice protection system unsteady modeling, 6th AIAA Atmospheric and Space Environments Conference -AVIATION 2014, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01088749
Measurement of local convective heat transfer coefficients from a smooth and roughened NACA-0012 airfoil, Flight test data présentée à 26th Aerospace Sciences Meeting, 1988. ,
Design of Ice Protection Systems and Icing Certification Through the FENSAP-ICE System, 2003. ,
, Subsonic Aircraft Safety Icing Study (n o NASA/TM, 2008.
Convective heat and mass transfer, 1993. ,
Comparison of thermodynamic models for ice accretion on airfoils, International Journal of Numerical Methods for Heat & Fluid Flow, vol.28, issue.5, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-02302891
Equilibrium Temperature of an Unheated Icing Surface as a Function of Air Speed, Journal of the Aeronautical Sciences, vol.20, issue.1, pp.29-42, 1953. ,
Extension to the Messinger Model for Aircraft Icing, AIAA Journal, vol.39, issue.2, pp.211-218, 2001. ,
Study on k-w shear stress transport model corrections applied to rough wall turbulent hypersonic boundary layers, 2017. ,
Ice accretion simulation on multi-element airfoils using extended Messinger model, Heat and Mass Transfer, vol.45, issue.3, p.305, 2008. ,
A statistical review of aviation airframe icing accidents in the, 2004. ,
Aero-thermal optimization of in-flight electrothermal ice protection systems in transient de-icing mode, International Journal of Heat and Fluid Flow, vol.54, pp.167-182, 2015. ,
Weather-related aviation accident investigations at the national transportation safety board présentée à 11th Conference on Aviation, Range, and Aerospace Meterology, 2004. ,
3D Ice Accretion Simulation For Complex Configuration Basing On Improved Messinger Model, International Journal of Modern Physics: Conference Series, vol.19, pp.341-350, 2012. ,
