Hogwild!: A lock-free approach to parallelizing stochastic gradient descent, Proc. of the 24th Intl Conference on Neural Information Processing Systems, ser. NIPS'11, pp.693-701, 2011. ,
ASAP: asynchronous approximate data-parallel computation, CoRR, 2016. ,
Asynchronous complex analytics in a distributed dataflow architecture, CoRR, 2015. ,
Dual averaging for distributed optimization: Convergence analysis and network scaling, IEEE Trans. on Automatic Control, vol.57, issue.3, pp.592-606, 2012. ,
Network topology and communication-computation tradeoffs in decentralized optimization, Proc. of the IEEE, vol.106, pp.953-976, 2018. ,
The role of the network in distributed optimization algorithms, 2013. ,
Optimal algorithms for smooth and strongly convex distributed optimization in networks, Proc. of the 34th ICML, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01478317
, An Introduction to Statistical Learning: With Applications in R, 2014.
Convex optimization: Algorithms and complexity, Foundations and Trends in Machine Learning, vol.8, 2015. ,
Scaling distributed machine learning with the parameter server, Proc. of the 11th USENIX OSDI Conf, 2014. ,
Effective straggler mitigation: Attack of the clones, Proc. of the 10th USENIX Conf. NSDI, 2013. ,
Straggler mitigation in distributed optimization through data encoding, Proc. of NIPS, pp.5434-5442, 2017. ,
Near-Optimal Straggler Mitigation for Distributed Gradient Methods, Proc. of the 7th Intl. Workshop ParLearning, 2018. ,
Distributed subgradient methods for multi-agent optimization, IEEE Trans. Automat. Contr, vol.54, issue.1, pp.48-61, 2009. ,
Equivalence, reversibility, symmetry and concavity properties in fork-join queuing networks with blocking, J. ACM, vol.41, issue.5, pp.903-942, 1994. ,
Throughput scalability analysis of fork-join queueing networks, Operations Research, 2018. ,
The expected eigenvalue distribution of a large regular graph, Linear Algebra and its Applications, vol.40, pp.203-216, 1981. ,
, UCI Machine Learning Repository
2D Image Registration in CT Images Using Radial Image Descriptors, Proc. of MICCAI, pp.607-614, 2011. ,
Searching for exotic particles in high-energy physics with deep learning, Nature communications, vol.5, p.4308, 2014. ,
Uniform generation of random regular graphs of moderate degree, J. Algorithms, vol.11, issue.1, pp.52-67, 1990. ,
Impact of communication delays on the convergence rate of distributed optimization algorithms, Proc. of ACM SIGMETRICS, 2018. ,
