High molecular diversity of extraterrestrial organic matter in Murchison meteorite revealed 40 years after its fall, Proc. Natl. Acad. Sci, vol.107, p.2763, 2010. ,
The amino acid and hydrocarbon contents of the Paris meteorite: Insights into the most primitive CM chondrite, Meteor. Planet. Sci, vol.50, pp.926-943, 2015. ,
Determination of the petrologic type of CV3 chondrites by Raman spectroscopy of included organic matter, Geochimica et Cosmochimica Acta, vol.70, pp.1849-1863, 2006. ,
URL : https://hal.archives-ouvertes.fr/insu-00357182
Characterization of insoluble organic matter in primitive meteorites by microRaman spectroscopy. Meteor, Planet. Sci, vol.42, pp.1387-1416, 2007. ,
Compositional diversity in insoluble organic matter in type 1, 2 and 3 chondrites as detected by infrared spectroscopy, Geochimica et Cosmochimica Acta, vol.75, pp.3530-3541, 2011. ,
Mid-infrared study of the molecular structure variability of insoluble organic matter from primitive chondrites, Icarus, vol.223, pp.534-543, 2013. ,
Model of molecular structure of the insoluble organic matter isolated from Murchison meteorite. Meteor, Planet. Sci, vol.45, pp.1461-1475, 2010. ,
High molecular diversity of extraterrestrial organic matter in Murchison meteorite revealed 40 years after its fall, Proc. Natl. Acad. Sci, vol.107, 2010. ,
Speciation of sulfur in the insoluble organic matter from carbonaceous chondrites by XANES spectroscopy, Earth Planet. Sci. Lett, vol.300, pp.321-328, 2010. ,
URL : https://hal.archives-ouvertes.fr/bioemco-00575865
NMR studies of chemical structural variation of insoluble organic matter from different carbonaceous chondrite groups, Geochimica et Cosmochimica Acta, vol.69, pp.1085-1097, 2005. ,
Hydropyrolysis of insoluble carbonaceous matter in the Murchison meteorite: New insights into its macromolecular structure, Geochimica et Cosmochimica Acta, vol.68, pp.1385-1393, 2004. ,
Indigenous amino acids in primitive CR meteorites, Meteor. Planet. Sci, vol.42, pp.2125-2136, 2007. ,
Extraterrestrial nucleobases in the Murchison meteorite, Earth Planet. Sci. Lett, vol.270, pp.130-136, 2008. ,
Enrichment of the amino acid L-isovaline by aqueous alteration on CI and CM meteorite parent bodies, Proc. Natl. Acad. Sci, vol.106, 2009. ,
Nitrogen-containing compounds in two CR2 meteorites: 15N composition, molecular distribution and precursor molecules, Geochimica et Cosmochimica Acta, vol.73, pp.2150-2162, 2009. ,
The effects of parent body processes on amino acids in carbonaceous chondrites, Meteor. Planet. Sci, vol.45, pp.1948-1972, 2010. ,
Carbonaceous meteorites contain a wide range of extraterrestrial nucleobases, Proc. Natl. Acad. Sci, pp.13995-13998, 2011. ,
The soluble organic compounds of the Bells meteorite: Not a unique or unusual composition, Geochimica et Cosmochimica Acta, vol.75, pp.7585-7595, 2011. ,
Orbitrap-MS and FT-ICR-MS of free and labile organic matter from carbonaceous chondrites, Proceedings of the 42nd Lunar and Planetary Science Conference, p.2654, 2011. ,
Alkylation of polycyclic aromatic hydrocarbons in carbonaceous chondrites, Geochimica et Cosmochimica Acta, vol.69, pp.1349-1357, 2005. ,
Identification of PAH Isomeric Structure in Cosmic Dust Analogues: The AROMA setup, Astrophys. J, vol.843, 2017. ,
Organic compounds in carbonaceous meteorites, Nat. Prod. Rep, vol.19, pp.292-311, 2002. ,
The nature, origin and modification of insoluble organic matter in chondrites, the major source of Earth's C and N, Chemie der Erde, vol.77, pp.227-256, 2017. ,
Relationships between organics, water and early stages of aqueous alteration in the pristine CR3.0 chondrite MET 00426, Geochimica et Cosmochimica Acta, vol.131, pp.344-367, 2014. ,
Prebiotic carbon in clays from Orgueil and Ivuna (CI), and Tagish Lake (C2 ungrouped) meteorites. Meteor, Planet. Sci, vol.42, pp.2111-2117, 2007. ,
Evolution of organic matter in Orgueil, Murchison and Renazzo during parent body aqueous alteration: In situ investigations, Geochimica et Cosmochimica Acta, vol.131, pp.368-392, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01001937
The paris CM chondrite yields new insights on the onset of parent body alteration, Proceedings of the 73rd Annual Meteoritical Society Meeting, pp.26-30, 2010. ,
The slightly altered, slightly metamorphosed CM that bridges the gap between CMs and COs, Proceedings of the 41st Lunar and Planetary Science Conference, p.1683, 2010. ,
Secondary processes within the paris CM chondrite, Proceedings of the 74th Annual Meteoritical Society Meeting, p.5099, 2011. ,
Chlorine in the paris CM: A preliminary study, Proceedings of the 74th Annual Meteoritical Society Meeting, pp.8-12, 2011. ,
Parent Body Influence on Organic Matter: The Message from Paris, Proceedings of the 74th Annual Meteoritical Society Meeting, p.5327, 2011. ,
The Paris CM chondrite: Secondary minerals and asteroidal processing, Meteor. Planet. Sci, vol.49, pp.1232-1249, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01053040
GEMS-like material in the matrix of the Paris meteorite and the early stages of alteration of CM chondrites, Geochimica et Cosmochimica Acta, vol.170, pp.247-265, 2015. ,
The Paris meteorite, the least altered CM chondrite so far, Geochimica et Cosmochimica Acta, vol.124, pp.190-222, 2014. ,
URL : https://hal.archives-ouvertes.fr/insu-00915172
On the characterization of the "paris" meteorite using PIXE, RBS and micro-PIXE, Nucl. Instrum. Methods Phys. Res. Sect. B, vol.306, pp.261-264, 2013. ,
URL : https://hal.archives-ouvertes.fr/in2p3-00852225
A dual origin for water in carbonaceous asteroids revealed by CM chondrites, Nat. Astron, vol.2, pp.317-323, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-02285395
, Carbon and nitrogen in carbonaceous chondrites: Elemental abundances and stable isotopic compositions. Meteor. Planet. Sci, vol.41, pp.1899-1918, 2006.
Hydrocarbon materials of likely interstellar origin from the Paris meteorite, Astrophys. J, vol.756, 2012. ,
Organic and mineralogic heterogeneity of the Paris meteorite followed by FTIR hyperspectral imaging, Meteor. Planet. Sci, vol.53, pp.2608-2623, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-02405177
Murchison: Impact of hydrothermal alteration on organic matter in CM chondrites, Geochimica et Cosmochimica Acta, vol.212, pp.234-252, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-02107274
Sequential analysis of carbonaceous materials in Hayabusa-returned samples for the determination of their origin, Earth Planets Space, vol.66, 2014. ,
ToF-SIMS analysis of carbonaceous particles in the sample catcher of the Hayabusa spacecraft, Earth Planets Space, vol.67, 2015. ,
The geomorphology, color, and thermal properties of Ryugu: Implications for parent-body processes, Science, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02381734
67P/Churyumov-Gerasimenko surface properties as derived from CIVA panoramic images, Science, vol.349, p.671, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-02373387
, analysis of interplanetary dust. Earth Planet. Sci. Lett, vol.128, pp.453-467, 1994.
TOF-SIMS analysis of crater residues from Wild 2 cometary particles on Stardust aluminum foil. Meteor, Planet. Sci, vol.43, pp.161-185, 2008. ,
, Stardust aerogel. Meteor. Planet. Sci, vol.43, pp.285-298, 2008.
, analysis of cometary matter in Stardust aerogel tracks. Meteor. Planet. Sci, vol.43, pp.233-246, 2008.
TOF-SIMS analysis of Allende projectiles shot into silica aerogel, Meteor. Planet. Sci, vol.41, pp.211-216, 2006. ,
A cornucopia of presolar and early solar system materials at the micrometer size range in primitive chondrite matrix, Meteor. Planet. Sci, vol.42, pp.1417-1427, 2007. ,
3-D elemental and isotopic composition of presolar silicon carbides. Meteor, Planet. Sci, vol.42, pp.1121-1134, 2007. ,
A combined ToF-SIMS and EMP/SEM study of a three-phase symplectite in the Los Angeles basaltic shergottite, Meteor. Planet. Sci, vol.44, pp.1225-1237, 2009. ,
TOF-SIMS analysis of polycyclic aromatic hydrocarbons in Allan Hills 84001, Meteor. Planet. Sci, vol.38, pp.109-116, 2003. ,
A tool for high-resolution mapping of elements and organic compounds, Geochimica et Cosmochimica Acta, vol.72, p.807, 2008. ,
Analysis of Prebiotic Organic Compounds in the Murchison Meteorite, Proceedings of the 46th Lunar and Planetary Science Conference, p.2513, 2015. ,
Visible-IR and Raman microspectroscopic investigation of three Itokawa particles collected by Hayabusa: Mineralogy and degree of space weathering based on nondestructive analyses, Meteor. Planet. Sci, vol.50, pp.1562-1576, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01771565
Mid-IR, Far-IR, Raman micro-spectroscopy, and FESEM-EDX study of IDP L2021C5: Clues to its origin, Icarus, vol.212, pp.896-910, 2011. ,
Advances in elemental imaging of rocks using the AGLAE external microbeam, Nucl. Instrum. Methods Phys. Res. Sect. B Beam Interact. Mater. Atoms, vol.269, pp.2364-2372, 2011. ,
, , p.24, 2019.
The Guelph PIXE software package, Nucl. Instrum. Methods Phys. Res. Sect. B Beam Interact. Mater. Atoms, vol.43, pp.218-230, 1989. ,
High mass and spatial resolution mass spectrometry imaging of Nicolas Poussin painting cross section by cluster TOF-SIMS, J. Mass Spectrom, vol.51, pp.1196-1210, 2016. ,
Biological tissue imaging with time-of-flight secondary ion mass spectrometry and cluster ion sources, J. Mass Spectrom, vol.40, pp.985-999, 2005. ,
, , 1994.
Surface modification with gas cluster ion beams from fundamental characteristics to applications, Nucl. Instrum. Methods Phys. Res. Sect. B Beam Interact. Mater. Atoms, vol.216, pp.379-389, 2004. ,
Interaction agrégat-surface. Spectrométrie de masse par temps de vol et application analytique à des études sur des médicaments et sur la météorite Paris, Life, vol.9, p.44, 2013. ,
Spectral reflectance properties of carbonaceous chondrites: 2. CM chondrites, Icarus, vol.216, pp.309-346, 2011. ,
The taxonomic distribution of asteroids from multi-filter all-sky photometric surveys, Icarus, vol.226, pp.723-741, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00844029
Refractory and semi-volatile organics at the surface of comet 67P/Churyumov-Gerasimenko: Insights from the VIRTIS/Rosetta imaging spectrometer, Icarus, vol.272, pp.32-47, 2016. ,
Mid-infrared spectroscopy laboratory data: Chapter 4, Remote Geochemical Analysis ,
, , 1993.
Infrared study of goethites of varying crystallinity and particle size: I. Interpretation of OH and lattice vibration frequencies, Clay Miner, vol.21, pp.191-200, 1986. ,
Infrared spectroscopy of goethite dehydroxylation: III. FT-IR microscopy of in situ study of the thermal transformation of goethite to hematite, Spectrochim. Acta Part A Mol. Biomol. Spectrosc, vol.58, pp.967-981, 2002. ,
Reflectance and Emission Spectroscopy Study of Four Groups of Phyllosilicates: Smectites, Kaolinite-Serpentines, Chlorites and Micas, Clay Miner, vol.43, pp.35-54, 2008. ,
Hydrous mineralogy of CM and CI chondrites from infrared spectroscopy and their relationship with low albedo asteroids, Geochimica et Cosmochimica Acta, vol.74, pp.4881-4892, 2010. ,
URL : https://hal.archives-ouvertes.fr/insu-00549075
Transmission infrared spectra (2-25 µm) of carbonaceous chondrites, Mineralogy, water, and asteroidal processes, vol.229, pp.263-277, 2014. ,
2-16 µm spectroscopy of micron-sized enstatite (Mg,Fe) 2 Si 2 O 6 silicates from primitive chondritic meteorites, Mon. Not. R. Astron. Soc, vol.376, pp.1367-1374, 2007. ,
IR spectroscopic study of olivine, enstatite and diopside irradiated with low energy H+ and He+ ions, Astron. Astrophys, vol.420, pp.233-243, 2004. ,
Mid-infrared spectra of the shocked Murchison CM chondrite: Comparison with astronomical observations of dust in debris disks, Icarus, vol.207, pp.45-53, 2010. ,
, , 2019.
The power of databases: The RRUFF project, Highlights in Mineralogical Crystallography ,
, , 2015.
Origin of insoluble organic matter in type 1 and 2 chondrites: New clues, new questions, Geochimica et Cosmochimica Acta, vol.136, pp.80-99, 2014. ,
URL : https://hal.archives-ouvertes.fr/in2p3-01057484
Abundances of the elements in the Solar System, Landolt-Börnstein-Group VI Astronomy and Astrophysics 4B, vol.4, 2009. ,
The solar system abundances of phosphorus and titanium and the nebular volatility of phosphorus, Meteor. Planet. Sci, vol.36, pp.559-571, 2001. ,
Aragonite, breunnerite, calcite and dolomite in the CM carbonaceous chondrites: High fidelity recorders of progressive parent body aqueous alteration, Geochimica et Cosmochimica Acta, vol.144, pp.126-156, 2014. ,
Hematite-Goethite relations in neutral and alkaline solutions under pressure, Am. Mineral, vol.34, p.403, 1949. ,
A re-examination of the stability of goethite on Mars, J. Geophys. Res, vol.75, pp.7491-7500, 1970. ,
The transformation of ferrihydrite into goethite or hematite, revisited, J. Solid State Chem, vol.179, pp.716-722, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00496126
On the goethite to hematite phase transformation, J. Therm. Anal. Calorim, vol.102, pp.867-873, 2010. ,
Coordinated NanoSIMS and FIB-TEM analyses of organic matter and associated matrix materials in CR3 chondrites, Geochimica et Cosmochimica Acta, vol.139, pp.1-25, 2014. ,
D/H and 15N/14N isotopic ratios in organic matter of ultracarbonaceous antarctic micrometeorites, Proceedings of the 78th Annual Meeting of the Meteoritical Society, p.5275, 2015. ,
6 micron absorption features due to solid phase CO and cyano group molecules toward compact infrared sources, Astrophys. J, vol.276, pp.533-543, 1984. ,
Further evidence for the OCN-assignment to the XCN band in astrophysical ice analogs, Astron. Astrophys, vol.309, pp.633-647, 1996. ,
Radiolysis of ammonia-containing ices by energetic, heavy, and highly charged ions inside dense astrophysical environments, Astron. Astrophys, vol.509, p.87, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00453023
, First detection of ammonium salts on a cometary nucleus, revealing a new reservoir of nitrogen. Sci. Adv. 2019. under review
12-Mineral Matrices and Organic Matter, Treatise on Geochemistry, vol.12, pp.337-359, 2014. ,
Previously unknown class of metalorganic compounds revealed in meteorites, Proc. Natl. Acad. Sci, vol.114, pp.2819-2824, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01534828
Localized aliphatic organic material on the surface of Ceres, vol.355, p.719, 2017. ,
Available online: www.sshade.eu (accessed on, p.24, 2019. ,
SSHADE in H2020: Development of an European Database Infrastructure in Solid Spectroscopy, Proceedings of the European Planetary Science Congress, p.628, 2015. ,
, Paucity of Tagish Lake-like parent bodies in the Asteroid Belt and among Jupiter Trojans, vol.225, pp.517-525, 2013.
URL : https://hal.archives-ouvertes.fr/hal-01439462
Interplanetary dust particles as samples of icy asteroids, Astrophys. J, vol.806, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01439933
Compositional Homogeneity of CM Parent Bodies, Astron. J, vol.152, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01440118
The surface composition of asteroid 162173 Ryugu from Hayabusa2 near-infrared spectroscopy, Science, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02405166
The organic-rich surface of comet 67P/Churyumov-Gerasimenko as seen by VIRTIS/Rosetta, Science, vol.347, 2015. ,
NIR reflectance hyperspectral microscopy for planetary science: Application to the MicrOmega instrument, Planet. Space Sci, vol.76, pp.42-52, 2013. ,
Carbon-rich dust in comet 67P/Churyumov-Gerasimenko measured by COSIMA/Rosetta, Mon. Not. R. Astron. Soc, vol.469, pp.712-722, 2017. ,
Detection of ice and organics on an asteroidal surface, Nature, vol.464, p.1322, 2010. ,
Liquid metal ion sources: Mechanism and applications, Nucl. Instrum. Methods Phys. Res, vol.218, pp.347-353, 1983. ,
Current status of ionized-cluster beam technique: A low energy ion beam deposition, Nucl. Instrum. Methods Phys. Res. Sect. B, vol.21, pp.120-123, 1987. ,
Topography Measurements Using High Mass Resolution Time of Flight Secondary Ion Mass Spectrometry: Application To Banknotes, Anal. Chem. 2019. under review ,
URL : https://hal.archives-ouvertes.fr/hal-02277857
Cu and Zn Isotopic Variations in Carbonaceous Chondrites and Iron Meteorites, Proceedings of the 64th Annual Meteoritical Society Meeting, p.5123, 2001. ,
