On a simulation scheme for the Boltzmann equation, Math. Methods Appl. Sci, vol.8, pp.223-233, 1986. ,
Fluid dynamics limits of kinetic equations I. Formal derivation, J. Stat. Phys, vol.63, pp.323-344, 1991. ,
Uniformly stable numerical schemes for the Boltzmann equation preserving the compressible Navier-Stokes asymptotics, J. Comput. Phys, vol.227, pp.3781-3803, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00348598
, Molecular gas dynamics and direct simulation of gas flows, 1994.
Numerical simulation of the stationary onedimensional Boltzmann equation by particle methods, European J. Mech. B Fluids, pp.103-118, 1996. ,
Kernel density estimation via diffusion, Annals of Statistics, vol.38, pp.2916-2957, 2010. ,
Collisional delta-f scheme with evolving background for transport time scale simulations, Phys. of Plasmas, p.12, 1999. ,
Linear delta-f simulations of nonlocal electron heat transport, Phys. of Plasmas, p.7, 2000. ,
A hybrid particle approach for continuum and rarefied flow simulation, J. Comput. Phys, vol.228, pp.460-475, 2009. ,
, , vol.7, pp.1-49, 1998.
Direct simulation Monte Carlo schemes for Coulomb interactions in plasmas, Commun. Appl. Ind. Math, vol.1, pp.72-91, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00992107
A hybrid method for accelerated simulation of Coulomb collisions in a plasma, SIAM MMS, vol.7, pp.865-887, 2008. ,
Noiseless Vlasov-Poisson simulations with linearly transformed particles, J. Comput. Phys, vol.275, pp.236-256, 2014. ,
Towards smooth particle methods without smoothing, J. Sci. Comput, vol.65, pp.54-82, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00649821
Uniform convergence of a linearly transformed particle method for the Vlasov-Poisson system, SIAM J. Numer. Anal, vol.54, pp.137-160, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01080732
The Boltzmann equation and its applications, 1988. ,
Kinetic/fluid micro-macro numerical schemes for Vlasov-Poisson-BGK equation using particles, Kin. Rel. Models, vol.5, pp.787-816, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00728875
Asymptotically complexity diminishing schemes (ACDS) for kinetic equations in the diffusive scaling, J. Comput. Phys, vol.394, pp.243-262, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01849671
Asymptotic preserving and time diminishing schemes for rarefied gas dynamics, Kin. Rel. Models, vol.10, pp.643-668, 2017. ,
An asymptotic preserving scheme based on a micro-macro decomposition for collisional Vlasov equations: diffusion and high-field scaling limits, Kin. Rel. Models, vol.4, pp.441-477, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00533327
The moment guided Monte Carlo method, International Journal for Numerical Methods in Fluids, vol.67, pp.189-213, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00408891
Fluid simulations with localized Boltzmann upscaling by direct simulation Monte-Carlo, J. Comput. Phys, vol.231, pp.2414-2437, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00933464
The hybrid moment guided Monte Carlo method for the Boltzmann equation, Kin. Rel. Models, vol.6, pp.291-315, 2013. ,
, Hybrid multiscale methods II. Kinetic equations, vol.6, pp.1169-1197, 2007.
A fluid solver independent hybrid method for multiscale kinetic equations, SIAM J. Sci. Comput, vol.32, pp.603-634, 2010. ,
Exponential Runge-Kutta methods for stiff kinetic equations, SIAM J. Numer. Anal, vol.49, pp.2057-2077, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00992113
High order asymptotic-preserving schemes for the Boltzmann equation, C. R. Math. Acad. Sci, pp.481-486, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00933518
Asymptotic preserving implicit-explicit Runge-Kutta methods for non linear kinetic equations, SIAM J. Num. Anal, vol.32, pp.1064-1087, 2013. ,
Numerical methods for kinetic equations, Acta Numerica, vol.32, pp.369-520, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00986714
Implicit-explicit linear multistep methods for stiff kinetic equations, SIAM J. Numer. Anal, vol.55, pp.664-690, 2017. ,
Asymptotic Preserving Monte Carlo methods for transport equations in the diffusive limit, SIAM J. Sci. Comput, vol.40, pp.504-528, 2018. ,
On steady-state preserving spectral methods for homogeneous Boltzmann equations, C. R. Math. Acad. Sci, vol.353, pp.309-314, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01053930
A class of asymptotic preserving schemes for kinetic equations and related problems with stiff sources, J. Comp. Phys, vol.229, pp.7625-7648, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00382560
, Geometric Numerical Integration. Structure-Preserving Algorithms for Ordinary Differential Equations, 2002.
URL : https://hal.archives-ouvertes.fr/hal-01403326
A low-variance deviational simulation Monte Carlo for the Boltzmann equation, J. Comp. Phys, vol.226, pp.2341-2358, 2007. ,
Low-variance deviational simulation Monte Carlo, Phys. Fluids, vol.19, p.41701, 2007. ,
Efficient Asymptotic-Preserving (AP) schemes for some multiscale kinetic equations, SIAM J. Sci. Comput, vol.21, pp.441-454, 1999. ,
An asymptotic-induced scheme for non stationary transport equations in the diffusive limit, SIAM J. Numer. Anal, vol.35, pp.1073-1094, 1998. ,
Transition from kinetic theory to macroscopic fluid equations: a problem for domain decomposition and a source for new algorithms, Transport Theory and Statistical Physics, vol.29, pp.93-106, 2000. ,
Asymptotic preserving numerical schemes for a nonclassical radiation transport model for atmospheric clouds, Math. Meth. Applied Sci, vol.36, pp.2101-2116, 2013. ,
Asymptotic-preserving projective integration schemes for kinetic equations in the diffusion limit, SIAM J. Sci. Comp, vol.34, pp.579-602, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00485189
Monte Carlo simulation of excitation and ionization collisions with complexity reduction, J. Comput. Phys, vol.346, pp.480-496, 2017. ,
Relaxed micro-macro schemes for kinetic equations, C. R. Math. Acad. Sci. Paris, vol.348, pp.455-460, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00521523
A new asymptotic preserving scheme based on micro-macro formulation for linear kinetic equations in the diffusion limit, SIAM J. Sci. Comp, vol.31, pp.334-368, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00348594
Diffusion approximations and domain decomposition method of linear transport equations: Asymptotics and numerics, J. Comp. Phys, vol.292, pp.141-167, 2015. ,
Half-space Kinetic Equations with General Boundary Conditions, Math. Comp, vol.86, pp.1269-1301, 2016. ,
Monte Carlo strategies in scientific computing, 2004. ,
A multilevel Monte Carlo method for asymptotic-preserving particle schemes, 2019. ,
Fast algorithms for computing the Boltzmann collision operator, Math. Comp, vol.75, pp.1833-1852, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00087285
Direct simulation scheme derived from the Boltzmann equation, J. Phys. Soc. Japan, vol.49, pp.2042-2049, 1980. ,
Boltzmann simulation by particle methods, Proceeding "Boltzmannn's legacy 150 years after his birth ,
Particle methods for the Boltzmann equation, Acta numerica, vol.4, pp.417-457, 1995. ,
An introduction to Monte Carlo methods for the Boltzmann equation, ESAIM Proc, vol.10, pp.35-76, 1999. ,
Interacting Multiagent Systems: Kinetic Equations and Monte Carlo Methods, 2013. ,
On efficient simulations of multiscale kinetic transport, Phil. Trans. Royal Soc. A, vol.371, 2013. ,
An Asymptotic-Preserving Monte Carlo method for the Boltzmann equation, J. Comp. Phys, vol.276, pp.380-404, 2014. ,
On the construction and the comparison of difference schemes, SIAM J. Numer. Anal, vol.5, pp.506-517, 1968. ,
A particle-particle hybrid method for kinetic and continuum equations, J. Comput. Phys, vol.228, pp.7109-7124, 2009. ,
A hybrid method with deviational particles for spatial inhomogeneous plasma, J. Comput. Phys, vol.309, pp.18-36, 2016. ,
A Monte Carlo method with negative particles for Coulomb collisions, J. Comput. Phys, vol.298, pp.711-740, 2015. ,
