Zero-Sum Stochastic Games over the Field of Real Algebraic Numbers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Dynamic Games and Applications Année : 2019
We consider a finite state, finite action, zero-sum stochastic games with data defining the game lying in the ordered field of real algebraic numbers. In both the discounted and the limiting average versions of these games, we prove that the value vector also lies in the same field of real algebraic numbers. Our method supplies finite construction of univariate polynomials whose roots contain these value vectors. In the case where the data of the game are rational, the method also provides a way of checking whether the entries of the value vectors are also rational.
OrderedField19Dec2018(1).pdf (352.54 Ko) Télécharger le fichier
hal-02413402 , version 1 (16-12-2019)
Konstantin Avrachenkov, Vladimir Ejov, Jerzy Filar, Amir Moghaddam. Zero-Sum Stochastic Games over the Field of Real Algebraic Numbers. Dynamic Games and Applications, 2019, 9 (4), pp.1026-1041. ⟨10.1007/s13235-018-00293-w⟩. ⟨hal-02413402⟩
49 Consultations
124 Téléchargements
