Generalized optimization framework for graph-based semi-supervised learning, Proceedings of the 2012 SIAM International Conference on Data Mining, pp.966-974, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00633818
On the choice of kernel and labelled data in semi-supervised learning methods, Proccedings of WAW 2013, pp.56-67, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00924132
Semisupervised learning with regularized Laplacian, Optimization Methods and Software, vol.32, issue.2, pp.222-236, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01648135
Personalized PageRank with node-dependent restart, Proceedings of International Workshop on Algorithms and Models for the Web-Graph, pp.23-33, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01052482
Supervised random walks: predicting and recommending links in social networks, Proceedings of ACM WSDM 2011, pp.635-644, 2011. ,
Distance in Graphs, 1990. ,
Semi-Supervised Learning, 2006. ,
The graph bottleneck identity, Advances in Applied Mathematics, vol.47, pp.403-413, 2011. ,
A Class of graph-geodetic distances generalizing the shortest-path and the resistance distances, Discrete Applied Mathematics, vol.159, issue.5, pp.295-302, 2011. ,
The walk distances in graphs, Discrete Applied Mathematics, vol.160, pp.1484-1500, 2012. ,
Studying new classes of graph metrics, Proceedings of the SEE Conference, vol.8085, pp.207-214, 2013. ,
On the proximity measure for graph vertices provided by the inverse Laplacian characteristic matrix, The Institute of Mathematics and its Applications, in conjunction with the Manchester Center for Computational Mathematics, pp.6-7, 1995. ,
The matrix-forest theorem and measuring relations in small social groups, Autom. Remote Control, vol.58, issue.9, pp.1505-1514, 1997. ,
On a duality between metrics and ?-proximities, Autom. Remote Control, vol.59, issue.4, p.1501, 1998. ,
On proximity measures for graph vertices, Autom. Remote Control, vol.59, issue.10, pp.1443-1459, 1998. ,
Spectral graph theory, 1997. ,
The heat kernel as the pagerank of a graph, Proceedings of the National Academy of Sciences, vol.104, issue.50, pp.19735-19740, 2007. ,
, , 2011.
Encyclopedia of Distances, 2016. ,
Efficient clustering of very large document collections. Data mining for scientific and engineering applications, vol.2, pp.357-381, 2001. ,
Kernel k-means: spectral clustering and normalized cuts, Proceedings of ACM KDD, pp.551-556, 2004. ,
Statistical-mechanical approach to subgraph centrality in complex networks, Chem. Phys. Lett, vol.439, pp.247-251, 2007. ,
Communicability in complex networks, Physical Review E, vol.77, issue.3, p.36111, 2008. ,
Accounting for the role of long walks on networks via a new matrix function, Journal of Mathematical Analysis and Applications, vol.449, pp.1581-1600, 2017. ,
An experimental investigation of graph kernels on a collaborative recommendation task, Proceedings of the Sixth International Conference on Data Mining (ICDM'06), pp.863-868, 2006. ,
Algorithms and Models for Network Data and Link Analysis, 2016. ,
, Matrix Analysis, 2013.
Do logarithmic proximity measures outperform plain ones in graph clustering? In: Models, Algorithms, and Technologies for Network Analysis, Proceedings in Mathematics & Statistics, vol.197, pp.87-105, 2017. ,
A generalized inverse for graphs with absorption, Linear Algebra and its Applications, vol.537, pp.118-147, 2018. ,
Learning semantic similarity, Advances in Neural Information Processing Systems 15 (NIPS 15, pp.673-680, 2003. ,
A new status index derived from sociometric analysis, Psychometrika, vol.18, issue.1, pp.39-43, 1953. ,
, Group Inverses of M-matrices and Their Applications, 2012.
Developments in the theory of randomized shortest paths with a comparison of graph node distances, Physica A: Statistical Mechanics and its Applications, vol.393, pp.600-616, 2014. ,
Diffusion kernels on graphs and other discrete input spaces, Proceedings of ICML, pp.315-322, 2002. ,
A generalized distance in graphs and centered partitions, SIAM Journal on Discrete Mathematics, vol.11, issue.2, pp.293-304, 1998. ,
The link-prediction problem for social networks, Journal of the Association for Information Science and Technology, vol.58, issue.7, pp.1019-1031, 2007. ,
An Introduction to Kernel-Based Learning Algorithms, IEEE Transactions on Neural Networks, vol.12, issue.2, pp.181-202, 2001. ,
The PageRank citation ranking: Bringing order to the web, 1999. ,
Remarks to Maurice Fréchet's article "Sur la définition axiomatique d'une classe d'espace distanciés vectoriellement applicable sur l'espace de Hilbert, Ann. Math, vol.36, issue.3, pp.724-732, 1935. ,
Metric spaces and positive definite functions, Transactions of the American Mathematical Society, vol.44, issue.3, pp.522-536, 1938. ,
, , 2016.
Solution of the (m + 1)-terminal resistive network problem by means of metric geometry, Proceedings of the First Asilomar Conference on Circuits and Systems, pp.319-328, 1967. ,
Kernel Methods for Pattern Analysis, 2004. ,
Kernels and regularization on graphs, Learning Theory and Kernel Machines, pp.144-158, 2003. ,
Comparison of graph node distances on clustering tasks, Lecture Notes in Computer Science, vol.9886, pp.192-201, 2016. ,
Graph kernels, Journal of Machine Learning Research, vol.11, pp.1201-1242, 2010. ,
Semi-supervised learning on directed graphs, Proceeedings of NIPS, pp.1633-1640, 2004. ,
