A new instrument to measure the surface resistance of superconducting samples at 400 MHz, Review of Scientific Instruments, vol.74, pp.3390-3394, 2003. ,
Commissioning Results of the HZB Quadrupole Resonator, Proc. 17th Int. Conf. RF Superconductivity (SRF'15), vol.1, pp.930-936, 2015. ,
SRF Material Performance Studies using a Sample Host Cavity, Proc. 5th Int. Particle Accelerator Conf. (IPAC'14), pp.2638-2640, 2014. ,
Calorimeters for precision power dissipation measurements on controlled-temperature superconducting radiofrequency samples, Rev. Sci. Instrum, vol.83, p.124905, 2012. ,
Development of a TE011 Cavity for Thin-Films Study, Proc ,
Germany, RF Superconductivity (SRF'09), vol.039, pp.293-296, 2009. ,
Superconducting Surface Resistance Measurements with a TE011 Cavity, Proc. 2nd European Particle Accelerator Conf. (EPAC'90), pp.1106-1109, 1990. ,
Surface Resistance Measurements of Superconducting Samples with Vacuum Insulated Thermometers, Proc. 6th European Particle Accelerator Conf. (EPAC'98), vol.05, pp.1873-1875, 1998. ,
Parametrization of the niobium thermal conductivity in the superconducting state, Superconductor Science and Technology, vol.9, pp.453-460, 1996. ,
