Verification of the Coupled-Momentum Method with Womersley's Deformable Wall Analytical Solution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal for Numerical Methods in Biomedical Engineering Année : 2019
In this paper, we perform a verification study of the Coupled-Momentum Method (CMM), a 3D fluid-structure interaction (FSI) model which uses a thin linear elastic membrane and linear kinematics to describe the mechanical behavior of the vessel wall. The verification of this model is done using Womersley's deformable wall analytical solution for pulsatile flow in a semi-infinite cylindrical vessel. This solution is, under certain premises, the analytical solution of the CMM and can thus be used for model verification. For the numerical solution, we employ an impedance boundary condition to define a reflection-free outflow boundary condition and thus mimic the physics of the analytical solution, which is defined on a semi-infinite domain. We first provide a rigorous derivation of Womersley's deformable wall theory via scale analysis. We then illustrate different characteristics of the analytical solution such as space-time wave periodicity and attenuation. Finally, we present the verification tests comparing the CMM with Womersley's theory.
CMM_verification_-Final_Revision2 - with Figures.pdf (1.87 Mo) Télécharger le fichier
hal-02414672 , version 1 (16-12-2019)
Vasilina Filonova, Christopher J Arthurs, Irene Vignon-Clementel, C. Alberto Figueroa. Verification of the Coupled-Momentum Method with Womersley's Deformable Wall Analytical Solution. International Journal for Numerical Methods in Biomedical Engineering, 2019, ⟨10.1002/cnm.3266⟩. ⟨hal-02414672⟩
63 Consultations
263 Téléchargements
