The Power of Programs over Monoids in J
The model of programs over (finite) monoids, introduced by Barrington and Thérien, gives an interesting way to characterise the circuit complexity class $\mathsf{NC^1}$ and its subclasses and showcases deep connections with algebraic automata theory. In this article, we investigate the computational power of programs over monoids in $\mathbf{J}$, a small variety of finite aperiodic monoids. First, we give a fine hierarchy within the class of languages recognised by programs over monoids from $\mathbf{J}$, based on the length of programs but also some parametrisation of $\mathbf{J}$. Second, and most importantly, we make progress in understanding what regular languages can be recognised by programs over monoids in $\mathbf{J}$. We show that those programs actually can recognise all languages from a class of restricted dot-depth one languages, using a non-trivial trick, and conjecture that this class suffices to characterise the regular languages recognised by programs over monoids in $\mathbf{J}$.
