A note on the connection between product-form Jackson networks and counting lattice walks in the quarter plane - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
The ultimal goal is to find explicit solutions for counting generating functions (CGF) of some random walks in the quarter plane, starting from the wellknown product-form for the stationary distribution of customers in Jackson's stochastic networks. The first step is to solve a relativety simple boundary value problem (BVP) for the queueing system. Then, by using a variational principle based on the continuity with respect to adequate parameters, it is possible to transform some smooth curves in a continuous fashion and to get explicitly formulas for the conformal mappings of Riemann's theorem. This might be a new way of computing the gluing functions appearing in [1, 3], which are a key ingredient in the explicit formulas for CGFs.
Guy-Jackson-conformal-V2.pdf (226.67 Ko) Télécharger le fichier
hal-02415746 , version 1 (17-12-2019)
hal-02415746 , version 2 (06-01-2020)
  • HAL Id : hal-02415746 , version 1
Guy Fayolle. A note on the connection between product-form Jackson networks and counting lattice walks in the quarter plane. 2019. ⟨hal-02415746v1⟩
98 Consultations
85 Téléchargements
