Journal articles
Spatial Receptor Allocation for a Multiple Access Hub in Nanonetworks
Fazilet Gokbudak 1 Bayram Cevdet Akdeniz 2 Tuna Tugcu 3 Ali Emre Pusane 3
2 MARACAS - Modèle et algorithmes pour des systèmes de communication fiables
Inria Grenoble - Rhône-Alpes, CITI - CITI Centre of Innovation in Telecommunications and Integration of services
Abstract : Following the same trends in other communication schemes, design of star network topologies will gain importance in order to communicate with a centralized hub in molecular communications as well. For a molecular communication multiple access network system, interlink interference (ILI) becomes a crucial issue in addition to intersymbol interference (ISI). This paper focuses on spatial allocation of the receptors of a centralized receiver among transmitters by proposing efficient solutions to reduce both ISI and ILI. The spatial allocation scheme has been designed using an optimization problem and verified with Monte Carlo simulations.
Document type :
Journal articles
Complete list of metadata
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-02415965
Contributor : Bayram Cevdet Akdeniz Connect in order to contact the contributor
Submitted on : Tuesday, December 17, 2019 - 2:24:09 PM
Last modification on : Monday, May 16, 2022 - 4:54:01 PM
Long-term archiving on: : Wednesday, March 18, 2020 - 7:24:28 PM
File
08865649.pdf
Identifiers
Collections
Citation
Fazilet Gokbudak, Bayram Cevdet Akdeniz, Tuna Tugcu, Ali Emre Pusane. Spatial Receptor Allocation for a Multiple Access Hub in Nanonetworks. IEEE Transactions on Molecular, Biological and Multi-Scale Communications, IEEE, 2019, ⟨10.1109/TMBMC.2019.2946819⟩. ⟨hal-02415965⟩
Share
Metrics
Record views
31
Files downloads
91
