A comprehensive survey of recent advancements in molecular communication, IEEE Commun. Surveys Tuts, vol.18, issue.3, pp.1887-1919, 2016. ,
Diffusionbased nanonetworking: A new modulation technique and performance analysis, IEEE Commun. Lett, vol.17, issue.4, pp.645-648, 2013. ,
ISI mitigation techniques in molecular communication, IEEE Trans ,
, Mol. Biol. Multi-Scale Commun, vol.1, issue.2, pp.202-216, 2015.
D-MoSK modulation in molecular communications, IEEE Trans. Nanobiosci, vol.14, issue.6, pp.680-683, 2015. ,
ISI-avoiding modulation for diffusionbased molecular communication, IEEE Trans. Mol. Biol. Multi-Scale Commun, vol.3, issue.1, pp.48-59, 2017. ,
Optimal reception delay in diffusion-based molecular communication, IEEE Commun. Lett, vol.22, issue.1, pp.57-60, 2018. ,
Molecular communication options for long range nanonetworks, Comput. Netw, vol.53, issue.16, pp.2753-2766, 2009. ,
Establishing digital molecular communications in blood vessels, Proc. 1st Int. Black Sea Conf. Commun. Netw. (BlackSeaCom), pp.54-58, 2013. ,
Molecular transport in microfluidic channels for flow-induced molecular communication, Proc. IEEE Int. Conf. Commun. Workshops (ICC), pp.766-770, 2013. ,
Channel capacity modelling of blood capillary-based molecular communication with blood flow drift, Proc. 4th ACM Int. Conf. Nanosc. Comput. Commun, 2017. ,
Channel model of molecular communication via diffusion in a vessellike environment considering a partially covering receiver, 2018. ,
System-theoretic analysis and leastsquares design of microfluidic channels for flow-induced molecular communication, IEEE Trans. Signal Process, vol.61, issue.20, pp.5000-5013, 2013. ,
Modeling duct flow for molecular communication, 2017. ,
, Conduction of Heat in Solids, 1959.
Threedimensional channel characteristics for molecular communications with an absorbing receiver, IEEE Commun. Lett, vol.18, issue.6, pp.929-932, 2014. ,
Modeling of ligand-receptor protein interaction in biodegradable spherical bounded biological micro-environments, IEEE Access, vol.6, pp.25007-25018, 2018. ,
Geometrical structure of Laplacian eigenfunctions, SIAM Rev, vol.55, issue.4, pp.601-667, 2013. ,
Inequalities for certain eigenvalues of a membrane of given area, J. Rational Mech. Anal, vol.3, pp.343-356, 1954. ,
An isoperimetric inequality for the N-dimensional free membrane problem, J. Rational Mech. Anal, vol.5, issue.4, pp.633-636, 1956. ,
, Partial Differential Equations and Boundary Value Problems, 2016.
Dispersion of soluble matter in solvent flowing slowly through a tube, Proc. Roy. Soc. London, A, Math. Phys. Sci, vol.219, issue.1137, pp.186-203, 1953. ,
Physicochemical Hydrodynamics: An Introduction, 2005. ,
