Computing period matrices and the Abel-Jacobi map of superelliptic curves - Archive ouverte HAL Access content directly
Journal Articles Mathematics of Computation Year : 2019
(1, 2, 3) , (4)
1
2
3
4
We present an algorithm for the computation of period matrices and the Abel-Jacobi map of complex superelliptic curves given by an equation y m = f (x). It relies on rigorous numerical integration of differentials between Weierstrass points, which is done using Gauss method if the curve is hyperelliptic (m = 2) or the Double-Exponential method. The algorithm is implemented and makes it possible to reach thousands of digits accuracy even on large genus curves.
periods.pdf (729.38 Ko) Télécharger le fichier
Dates and versions
hal-02416012 , version 1 (17-12-2019)
Identifiers
  • HAL Id : hal-02416012 , version 1
Cite
Pascal Molin, Christian Neurohr. Computing period matrices and the Abel-Jacobi map of superelliptic curves. Mathematics of Computation, 2019. ⟨hal-02416012⟩
215 View
280 Download
Share
