Representation of topography by porous barriers and objective interpolation of topographic data, Ocean Modelling, vol.67, pp.13-27, 2013. ,
A penalization method to take into account obstacles in viscous flows, Numerische Mathematik, vol.81, pp.497-520, 1999. ,
Large-Eddy Simulation over Complex Terrain Using an Improved Immersed Boundary Method in the Weather Research and Forecasting Model, Monthly Weather Review, vol.146, pp.2781-2797, 2018. ,
Two-way nesting in split-explicit ocean models: Algorithms, implementation and validation. Ocean Modelling 49-50, pp.1-21, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00690731
Numerical and analytical estimates of m2 tidal conversion at steep oceanic ridges, Journal of Physical Oceanography, vol.36, pp.1072-1084, 2006. ,
Cross-shelf structure of coastal upwelling: a two-dimensional expansion of ekman's theory and a mechanism for innershelf upwelling shutdown, J. Marine Research, vol.66, pp.589-616, 2008. ,
The role of Reynolds number in the fluidelastic instability of tube arrays, J. Fluids Structures, vol.73, pp.16-36, 2017. ,
Computation of turbulent flow past an array of cylinders using a spectral method with brinkman penalization, Eur. J. Mech./B, vol.20, pp.333-350, 2001. ,
An adaptive wavelet collocation method for fluid-structure interaction at high Reynolds numbers, SIAM J. Sci. Comput, vol.26, pp.1894-1915, 2005. ,
Three-dimensional Floquet stability analysis of the wake in cylinder arrays, J Fluid Mech, vol.592, pp.79-88, 2007. ,
The role of vortex wake dynamics in the flow-induced vibration of tube arrays, J. Fluids Struct, vol.27, pp.829-837, 2011. ,
Adaptive wavelet simulation of global ocean dynamics using a new Brinkman volume penalization, Geoscientific Model Development, vol.8, pp.3891-3909, 2015. ,
The generation of internal tides at abrupt topography. Deep Sea Research Part I: Oceanographic Research Papers, vol.50, pp.987-1003, 2003. ,
An Immersed Boundary Method for the Weather Research and Forecasting Model, Monthly Weather Review, vol.138, pp.796-817, 2010. ,
An Immersed Boundary Method Enabling Large-Eddy Simulations of Flow over Complex Terrain in the WRF Model, Monthly Weather Review, vol.140, pp.3936-3955, 2012. ,
Spurious diapycnal mixing in terrain-following coordinate models: The problem and a solution, Ocean Modelling, vol.26, pp.156-169, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00409317
Upwelling limitation by geostrophic onshore flow, J. Marine Research, vol.68, pp.37-62, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00766433
The pressure gradient conundrum of sigma coordinate ocean models, Journal of Atmospheric and Oceanic Technology, vol.11, pp.1126-1134, 1994. ,
Flow patterns around heart valves: a numerical method, J. Comput. Phys, vol.10, pp.252-271, 1972. ,
Adaptive volume penalization for ocean modeling, Ocean Dyn, vol.62, pp.1201-1215, 2012. ,
Smoothing, Filtering, and Boundary Effects, p.359, 1970. ,
The regional oceanic modeling system (ROMS): a split-explicit, free-surface, topography-following-coordinate oceanic model, Ocean Modelling, vol.9, pp.347-404, 2005. ,
