HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Independent of delay stabilization using implicit Lyapunov function method
Abstract : Nonlinear implicit Lyapunov function based control algorithms with delay in control and/or measurement channel are presented. The proposed control algorithms provide global asymptotic stability for all delays less than a certain threshold value and global asymptotic stability with respect to a compact set containing the origin for any delay over the threshold value. The algorithms are also applicable for the fast-varying delay and sampled-data cases. The theoretical results are supported by numerical simulations and comparison.
Document type :
Journal articles
Complete list of metadata
Cited literature [32 references]  Display  Hide  Download
https://hal.inria.fr/hal-02418531
Contributor : Denis Efimov Connect in order to contact the contributor
Submitted on : Wednesday, December 18, 2019 - 9:57:15 PM
Last modification on : Thursday, March 24, 2022 - 3:42:57 AM
Long-term archiving on: : Thursday, March 19, 2020 - 10:10:58 PM
File
_17-1551_03_MS.pdf
Identifiers
Citation
Konstantin Zimenko, Denis Efimov, Andrey Polyakov, Artem Kremlev. Independent of delay stabilization using implicit Lyapunov function method. Automatica, Elsevier, 2019, 101, pp.103-110. ⟨10.1016/j.automatica.2018.11.051⟩. ⟨hal-02418531⟩
Share
Metrics
Record views
26
Files downloads
108
