Kremlev Control of Systems with Arbitrary Bounded Input Delay Using Implicit Lyapunov Function Technique, European Control Conference (ECC, pp.1548-1553, 2018. ,
Time-delay systems: an overview of some recent advances and open problems, Automatica, vol.39, issue.10, pp.1667-1694, 2003. ,
Editorial: Networks and control, IEEE Control System Magazine, vol.21, issue.1, pp.22-99, 2001. ,
Editorial: Delay-Dependent Stability Criteria of Teleoperation Systems With Asymmetric Time-Varying Delays, IEEE Transactions on Robotics, vol.26, issue.5, pp.925-932, 2010. ,
Tutorial on Lyapunov-based methods for timedelay systems, European Journal of Control, vol.20, issue.6, pp.271-283, 2014. ,
Experimental Analysis of an Internet-Based Bilateral Teleoperation System With Motion and Force Scaling Using a Model Predictive Controller, IEEE Transactions on Industrial Electronics, vol.55, issue.9, pp.3290-3299, 2008. ,
Human-Oriented Control for Haptic Teleoperation, Proceedings of the IEEE, vol.100, issue.3, pp.623-647, 2012. ,
Introduction to Time-Delay Systems: Analysis and Control, 2014. ,
Adaptive Controller for Linear System with Input Delay and Output Disturbance, IEEE Transactions on Automatic Control, vol.61, issue.12, pp.4229-4234, 2016. ,
H? control of systems with I/O delay: A review of some problem-oriented methods, IMA Journal of Mathematical Control and Information, vol.19, issue.12, pp.185-200, 2002. ,
Sliding mode controller design for linear time delay systems, European Control Conference (ECC), pp.3780-3785, 1999. ,
Steady modes in relay control systems with delay. In Sliding mode control in engineering, 2002. ,
Asymptotic analysis of digital control systems, Autom. Remote Control, vol.49, pp.1175-1180, 1988. ,
Nonlinear Control Systems II, 1999. ,
Differential equations with discontinuous righthand sides, 1988. ,
Uniform Second-Order Sliding Mode Observer for mechanical systems, 11th International Workshop on Variable Structure Systems, 2010. ,
Accuracy of disturbed homogeneous sliding modes. the 13th Scientific Workshop VSS13, 2014. ,
Homogeneity of differential inclusions: Application to sliding modes, Control Conference (ECC 2015), pp.2458-2463, 2015. ,
Robust Stabilization of MIMO Systems in Finite/Fixed Time, Int. J. Robust. Nonlinear Control, vol.26, issue.1, pp.69-90, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01160052
, , 2003.
Development of homogeneity concept for time-delay systems, SIAM J. Control Optim, vol.52, issue.3, pp.1547-1566, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00956878
A general approach to synthesis problem, Doklady Academii Nauk SSSR, vol.248, pp.1051-1063, 1979. ,
Soft variable-structure controls: a survey, Automatica, vol.40, pp.1821-1844, 2004. ,
Homogeneity for time-delay systems, Proc. IFAC WC, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00628890
Lyapunov Functions and Stability in Control Theory, 2005. ,
Weighted homogeneity for time-delay systems: Finite-time and independent of delay stability, IEEE Trans. Automatic Control, vol.61, issue.1, pp.210-215, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01145321
Stability of functional differential equations, CA: Academic, 1986. ,
A note on delay robustness for homogeneous systems with negative degree, Automatica, vol.79, pp.178-184, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01419131
, Finite-time and fixed-time stabilization: Implicit Lyapunov function approach. Automatica, vol.51, pp.332-340, 2015.
URL : https://hal.archives-ouvertes.fr/hal-01098099
Generalized Feedback Homogenization and Stabilization of Linear MIMO Systems, European Control Conference (ECC 2018), pp.1987-1991, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01797150
Sliding mode control in the presence of input delay: A singular perturbation approach, Automatica, vol.48, issue.8, pp.1904-1912, 2012. ,
Identifiability analysis of linear delaydifferential systems, IMA Journal of Mathematical Control and Information, vol.19, issue.1-2, pp.73-81, 2002. ,
