On robust stability of sine-Gordon equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Emilia Fridman
  • Fonction : Auteur
  • PersonId : 838164
Jean-Pierre Richard
A perturbed sine-Gordon equation is considered under the restrictions on the model parameters corresponding to the single equilibrium in the noise-free case. First, a strict Lyapunov function is proposed for this dynamics and the conditions of strict passivity with a corresponding output are given. Second, the input-to-state stability property is investigated. The obtained theoretical results are illustrated by some simulations.
CDC19_0195_Emilia.pdf (1.69 Mo) Télécharger le fichier
hal-02418533 , version 1 (18-12-2019)
  • HAL Id : hal-02418533 , version 1
Denis Efimov, Emilia Fridman, Jean-Pierre Richard. On robust stability of sine-Gordon equation. Proc. IEEE CDC, Dec 2019, Nice, France. ⟨hal-02418533⟩
42 Consultations
167 Téléchargements
