A note on converse Lyapunov-Krasovskii theorems for nonlinear neutral systems in Sobolev spaces
The problem of existence of a Lyapunov-Krasovskii functional (LKF) for nonlinear neutral type time-delay systems is revisited considering the uniform stability analysis and the LKF in a Sobolev space of absolutely continuous functions with bounded derivatives.
Automatique / Robotique
