Velocity estimation of valve movement in oysters for water quality surveillance, IFAC-PapersOnLine, vol.48, issue.11, pp.333-338, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01162688
Robust qualitative estimation of time-varying contact rates in uncertain epidemics, Epidemics, pp.98-104, 2018. ,
Interval observers for SIR epidemic models subject to uncertain seasonality, Lecture Notes in Control and Information Sciences, vol.471, 2017. ,
Étude et implantation de quelques algorithmes en algèbre différentielle, 1994. ,
Differential Elimination and Biological Modelling, Gröbner Bases in Symbolic Analysis), vol.2, pp.111-139, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00139364
Computing representations for radicals of finitely generated differential ideals. Applicable Algebra in Engineering, vol.20, p.73, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00139061
On Symbolic Approaches to Integro-Differential Equations, Algebraic and Symbolic Computation Methods in Dynamical Systems, Advances in Delays and Dynamics, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01367138
On nonlinear observability, Proc. 1st Europ. Control Conf, pp.152-157, 1991. ,
Parametrization of nonlinear model structures as linear regressions, 11th IFAC World Congress on Automatic Control, vol.23, pp.317-321, 1990. ,
Algebra and algorithm for singularities of implicit differential equations, vol.4, 1997. ,
URL : https://hal.archives-ouvertes.fr/tel-00004947
Modeling Infectious Diseases in Humans and Animals, 2008. ,
Interval observer for uncertain time-varying SIR-SI epidemiological model of vector-borne disease, proceedings of ECC'18, the 16th annual European Control Conference, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01493078
Some theoretical problems in effective differential algebra and their relation to control theory, Proc. Nolcos, 1992. ,
Finitetime observers: Application to secure communication, IEEE Trans. Automatic Control, vol.53, issue.1, pp.356-360, 2008. ,
A class of nonlinear adaptive observers for SIR epidemic model, proceedings of ECC'18, the 16th annual European Control Conference, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01724989
Input estimation in nonlinear dynamical systems using differential algebra techniques, Automatica, vol.42, issue.12, pp.2117-2129, 2006. ,
Differential Algebra, Colloquium publications, 1950. ,
Parameter identifiability of nonlinear systems: the role of initial conditions, Automatica, vol.39, issue.4, pp.619-632, 2003. ,
A forecasting algorithm for latency compensation in indirect interaction, proceedings of ECC'16, the 15th annual European Control Conference, p.6, 2016. ,
