Entropy diminishing finite volume approximation of a cross-diffusion system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a two-point flux approximation finite volume scheme for the approximation of the solutions of a entropy dissipative cross-diffusion system. The scheme is shown to preserve several key properties of the continuous system, among which positivity and decay of the entropy. Numerical experiments illustrate the behaviour of our scheme.
CG_FVCA9_revised (1).pdf (11.57 Mo) Télécharger le fichier
hal-02418908 , version 1 (19-12-2019)
hal-02418908 , version 2 (30-01-2020)
  • HAL Id : hal-02418908 , version 2
Clément Cancès, Benoît Gaudeul. Entropy diminishing finite volume approximation of a cross-diffusion system. FVCA9 - International Conference on Finite Volumes for Complex Applications IX, 2020, Bergen, Norway. ⟨hal-02418908v2⟩
160 Consultations
38 Téléchargements
