Runtime Pointer Disambiguation, Proceedings of the 2015 ACM SIGPLAN International Conference on Object-Oriented Programming, Systems, Languages, and Applications, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01234086
ParaInsight: An Assistant for Quantitatively Analyzing Multigranularity Parallel Region, High Performance Computing and Communications & 2013 IEEE International Conference on Embedded and Ubiquitous Computing (HPCC_EUC), 2013 IEEE 10th International Conference on, 2013. ,
Generating loops for scanning polyhedra: Cloog users guide, Polyhedron, vol.2, 2004. ,
QEMU, a Fast and Portable Dynamic Translator, Proceedings of the Annual Conference on USENIX Annual Technical Conference (ATEC '05), 2005. ,
Fast data-locality profiling of native execution, ACM SIGMETRICS Performance Evaluation Review, 2005. ,
Discovery of Locality-Improving Refactorings by Reuse Path Analysis. High Performance Computing and Communications, 2006. ,
A Practical Automatic Polyhedral Parallelizer and Locality Optimizer, Proceedings of the 29th ACM SIGPLAN Conference on Programming Language Design and Implementation (PLDI '08), 2008. ,
Dynamic planar convex hull, The 43rd Annual IEEE Symposium on Foundations of Computer Science, 2002. ,
Runtime analysis of application binaries for function level parallelism potential using QEMU, Open Source Systems and Technologies (ICOSST), 2012 International Conference on, 2012. ,
Rodinia: A benchmark suite for heterogeneous computing, IEEE International Symposium on, 2009. ,
A Characterization of the Rodinia Benchmark Suite with Comparison to Contemporary CMP Workloads, Proceedings of the IEEE International Symposium on Workload Characterization (IISWC'10) (IISWC '10), 2010. ,
Fuzzy Array Dataflow Analysis, Proceedings of the Fifth ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming (PPOPP '95), 1995. ,
Optimistic Loop Optimization, Proceedings of the 2017 International Symposium on Code Generation and Optimization (CGO '17), 2017. ,
Embla -Data Dependence Profiling for Parallel Programming, Proceedings of the 2008 International Conference on Complex, Intelligent and Software Intensive Systems (CISIS '08), 2008. ,
Parametric integer programming, RAIRO-Operations Research, vol.22, p.3, 1988. ,
Polyhedron model, Encyclopedia of Parallel Computing, 2011. ,
Polly -Performing Polyhedral Optimizations on a Low-level Intermediate Representation, Parallel Processing Letters, vol.22, p.4, 2012. ,
Python implementation of the folding based analysis ,
Data-Flow/Dependence Profiling for Structured Transformations, ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02060796
Building of a Polyhedral Representation from an Instrumented Execution: Making Dynamic Analyses of non-Affine Programs Scalable, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02418987
Program Instrumentation with QEMU, Proceedings of the International QEMU User's Forum, 2011. ,
Convex hulls and related problems in data streams, Proc. of the ACM/DIMACS Workshop on Management and Processing of Data Streams, 2003. ,
Dynamic trace-based analysis of vectorization potential of applications, ACM SIGPLAN Notices, vol.47, p.6, 2012. ,
Prediction and Trace Compression of Data Access Addresses Through Nested Loop Recognition, Proceedings of the 6th Annual IEEE/ACM International Symposium on Code Generation and Optimization (CGO '08), 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00504597
Profiling Data-Dependence to Assist Parallelization: Framework, Scope, and Optimization, Proceedings of the 2012 45th Annual IEEE/ACM International Symposium on Microarchitecture (MICRO-45), 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00780782
Prospector: A dynamic data-dependence profiler to help parallel programming, HotParâ??10: Proceedings of the USENIX workshop on Hot Topics in parallelism, 2010. ,
DiscoPoP: A profiling tool to identify parallelization opportunities, Tools for High Performance Computing, 2014. ,
Pinpointing data locality problems using data-centric analysis, Code Generation and Optimization (CGO), 2011 9th Annual IEEE/ACM International Symposium on, 2011. ,
MIAMI: A framework for application performance diagnosis, 2014 IEEE International Symposium on Performance Analysis of Systems and Software (ISPASS), 2014. ,
Full runtime polyhedral optimizing loop transformations with the generation, instantiation, and scheduling of code-bones, Concurrency and Computation: Practice and Experience, vol.29, p.15, 2017. ,
Redux: A dynamic dataflow tracer. Electronic Notes in Theoretical, Computer Science, vol.89, 2003. ,
PSnAP: Accurate Synthetic Address Streams through Memory Profiles, Languages and Compilers for Parallel Computing, 2010. ,
Induction Variable Analysis with Delayed Abstractions, Proceedings of the First International Conference on High Performance Embedded Architectures and Compilers (HiPEAC'05), 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-01257294
, the PoCC polyhedral compiler collection, 2019.
Trace-based Affine Reconstruction of Codes, Proceedings of the 2016 International Symposium on Code Generation and Optimization (CGO '16), 2016. ,
Hybrid Analysis: Static & Dynamic Memory Reference Analysis, International Journal of Parallel Programming, vol.31, 2003. ,
Simplification and Runtime Resolution of Data Dependence Constraints for Loop Transformations, Proceedings of the International Conference on Supercomputing (ICS '17), 2017. ,
PolyJIT: Polyhedral Optimization Just in Time, International Journal of Parallel Programming, 2018. ,
Beyond the Realm of the Polyhedral Model: Combining Speculative Program Parallelization with Polyhedral Compilation. Theses, 2015. ,
URL : https://hal.archives-ouvertes.fr/tel-01251748
The Polyhedral Model of Nonlinear Loops, ACM Trans. Archit. Code Optim, vol.12, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01244464
Semi-automatic Extraction and Exploitation of Hierarchical Pipeline Parallelism Using Profiling Information, Proceedings of the 19th International Conference on Parallel Architectures and Compilation Techniques (PACT '10), 2010. ,
GRAPHITE Two Years After: First Lessons Learned From Real-World Polyhedral Compilation, GCC Research Opportunities Workshop, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00551516
Efficient symbolic analysis for optimizing compilers, International Conference on Compiler Construction, 2001. ,
The Paralax infrastructure: automatic parallelization with a helping hand, Parallel Architectures and Compilation Techniques (PACT), 2010 19th International Conference on, 2010. ,
José Ignacio Gómez, Christian Tenllado, and Francky Catthoor, ACM Trans. Archit. Code Optim, vol.9, issue.4, 2013. ,
Integrating profile-driven parallelism detection and machine-learning-based mapping, ACM Transactions on Architecture and Code Optimization (TACO), vol.11, p.1, 2014. ,
