Competitive advantage, customization and a new taxonomy for non-make-to-stock companies, Internasjonal Journal of Operations & production management, pp.349-371, 1999. ,
Integrating production and engineering perspectives on the customer order decoupling point, International Journal of Operations & Production Management, vol.25, issue.7, pp.623-641, 2005. ,
Engineer-to-order supply chain management: A litterature review and research agenda, International Journal of Production Economics, pp.741-754, 2009. ,
The flexibility paradox: Achieving ambidexterity in high-variety, low-volume manufacturing, Global Journal of flexibility systems management, pp.69-86, 2018. ,
Conwip; a pull alternative to kanban, International Journal of Proudction Research, pp.879-894, 1990. ,
The practitioner's guide to polca: The production control sysstem for high-mix low-volume and custom products, 2018. ,
Card-based workload control for job shops; Improving COBACABANA, International Journal of Production Economics, pp.180-188, 2014. ,
Performance analysis of an assembly station with input from multple fabrication lines, pp.283-302, 2000. ,
QRM and Polca: A winning combination for manufacturing enterprises in the 21st century, Center for quick response manufacturing, Madison WI 53706, 2003. ,
Queueing models for systems with synchronisation constraints, Proceedings of the IEEE, 1989. ,
Workload balancing capability of pull systems in MTO production, International Journal of Production Research, pp.2345-2360, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00565392
Creating mixed model value streams, 2013. ,
