Engineering maintenance: a modern approach, 2002. ,
Classifying plant operator maintenance proficiency: examining personal variables, Building Research & Information, vol.32, issue.2, pp.119-127, 2004. ,
Intelligence and maintenance proficiency: an examination of plant operators, Construction Innovation, vol.5, issue.4, pp.243-254, 2005. ,
Impact of experience on maintenance skills, Journal of Software Maintenance and Evolution, vol.14, issue.2, pp.123-146, 2002. ,
On modeling failure and repair times in stochastic models of manufacturing systems using generalized exponential distributions. Queueing Systems, vol.15, pp.199-209, 1994. ,
A cold standby repairable system with working vacations and vacation interruption following Markovian arrival process, Reliability Engineering & System Safety, vol.142, pp.1-8, 2015. ,
A cold standby repairable system with the repairman having multiple vacations and operational, repair, and vacation times following phase-type distributions, Communications in Statistics-Theory and Methods, vol.45, issue.4, pp.850-858, 2016. ,
An improved negative binomial approximation for negative hypergeometric distribution, In Applied Mechanics and Materials. Trans Tech Publications, vol.427, pp.2549-2553, 2013. ,
