Literature review of JIT-KANBAN system, The International Journal of Advanced Manufacturing Technology, vol.32, issue.3-4, pp.393-408, 2007. ,
Extended kanban control system: combining kanban and base stock, IIE transactions, vol.32, issue.4, pp.369-386, 2000. ,
Data mining using genetic programming for construction of a semiconductor manufacturing yield rate prediction system, Journal of Intelligent Manufacturing, vol.17, pp.355-361, 2006. ,
Using a neural network-based approach to predict the wafer yield in integrated circuit manufacturing, IEEE Transactions on Components, Packaging, and Manufacturing Technology: Part C, vol.20, issue.4, pp.288-294, 1997. ,
Novel yield model for integrated circuits with clustered defects, Expert Systems with Applications, vol.34, issue.4, pp.2334-2341, 2008. ,
A fuzzy-neural system incorporating unequally important expert opinions for semiconductor yield forecasting, International Journal of Uncertainty, Fuzziness and Knowledge-Based Systems, vol.16, issue.01, pp.35-58, 2008. ,
Fuzzy neural network based yield prediction model for semiconductor manufacturing system, International Journal of Production Research, vol.48, issue.11, pp.3225-3243, 2010. ,
Recognizing yield patterns through hybrid applications of machine learning techniques, Information Sciences, vol.179, issue.6, pp.844-850, 2009. ,
Yield prediction using support vectors based under-sampling in semiconductor process, International Scholarly and Scientific Research & Innovation, vol.6, issue.12, pp.2755-2759, 2012. ,
Product Design for Assembly, Boothroyd Dewhurst Incorporated, 1986. ,
Measuring the assembly quality from the operator mistake view: a case study, Assembly Automation, vol.29, issue.4, pp.332-340, 2009. ,
Global conformance quality model: A new strategic tool for minimizing defects caused by variation, error, and complexity, 1993. ,
Global assembly quality methodology: a new method for evaluating assembly complexities in globally distributed manufacturing, Ph.D. Dissertation, 2002. ,
A study of the effects of manufacturing complexity on product quality in mixed-model automotive assembly, Ph.D. Dissertation, 2014. ,
Prediction of defect propensity for the manual assembly of automotive electrical Connectors, Procedia Manufacturing, vol.5, pp.144-157, 2016. ,
Mixture density Networks, 1994. ,
A matchmaking methodology for supply chain deployment in distributed manufacturing environments, Journal of Computing and Information Science in Engineering, vol.8, issue.1, p.11002, 2008. ,
Development and application of a metric on semantic nets, IEEE transactions on systems, man, and cybernetics, vol.19, issue.1, pp.17-30, 1989. ,
Semantic similarity in a taxonomy: An information-based measure and its application to problems of ambiguity in natural language, Journal of artificial intelligence research, vol.11, pp.95-130, 1999. ,
A first course in probability, 2014. ,
Features of similarity, Psychological review, vol.84, issue.4, p.327, 1977. ,
