Effekt & Effektivitet, Dansk Dagligvarehandel, 2003. ,
Demand and Supply Chain Planning in Grocery Retail: an Operations Planning Framework, Int. J. Retail Distrib. Manag, vol.41, pp.512-530, 2013. ,
Effects of Food and Beverage Storage, Distribution, Display, and Consumer Handling on Shelf Life, pp.107-140, 2016. ,
Judgmental Selection of Forecasting Models, J. Oper. Manag, vol.60, pp.34-46, 2018. ,
Understanding Demand Management Challenges in Intermediary Food Trading: A Case Study, Supply Chain Manag. An Int. J, vol.14, pp.224-233, 2009. ,
Causes of Waste across Multi-Tier Supply Networks: Cases in the UK Food Sector, Int. J. Prod. Econ, vol.152, pp.144-158, 2014. ,
Business Forecasting, 2009. ,
Evaluating Predictive Count Data Distributions in Retail Sales Forecasting, Int. J. Forecast, vol.32, pp.788-803, 2016. ,
Advantages of the MAD/Mean Ratio over the MAPE, Foresight Int. J. Appl. Forecast, pp.40-43, 2007. ,
Evaluating Forecasting Methods by Considering Different Accuracy Measures, Procedia -Procedia Comput. Sci, vol.95, pp.264-271, 2016. ,
Another Look at Measures of Forecast Accuracy, Int. J. Forecast, vol.22, pp.679-688, 2006. ,
Another Look at Forecast-Accuracy Metrics for Intermittent Demand, Foresight Int. J. Appl. Forecast, pp.43-46, 2006. ,
Expertise, Credibility of System Forecasts and Integration Methods in Judgmental Demand Forecasting, Int. J. Forecast, vol.33, pp.298-313, 2017. ,
Sales and Operations Planning: Responding to the Needs of Industrial Food Producers, Prod. Plan. Control, vol.26, pp.280-295, 2015. ,
Proposals for Enhancing Tactical Planning in Grocery Retailing with S&OP, Int. J. Phys. Distrib. Logist. Manag, vol.48, pp.114-138, 2018. ,
The Implications of Fit between Planning Environments and Manufacturing Planning and Control Methods, Int. J. Oper. Prod. Manag, vol.23, pp.872-900, 2003. ,
Centralised Grocery Supply Chain Planning: Improved Exception Management, Int. J. Phys. Distrib. Logist. Manag, vol.45, pp.237-259, 2015. ,
Can Differentiated Production Planning and Control enable both Responsiveness and Efficiency in Food Production ?, Int. J. Food Syst. Dyn, pp.34-43, 2014. ,
Integrative retail logistics: An exploratory study, Oper. Manag. Res, vol.6, pp.2-18, 2013. ,
Impacts of Adaptive Collaboration on Demand Forecasting Accuracy of Different Product Categories Throughout the Product Life Cycle, Supply Chain Manag. An Int. J, vol.20, pp.415-433, 2015. ,
Demand Chain Alignment Competence -Delivering Value through Product Life Cycle Management, Ind. Mark. Manag, vol.35, pp.989-1001, 2006. ,
Examining Retail On Shelf Availability: Promotional Impact and a Call for Research, Int. J. Phys. Distrib. Logist. Manag, vol.42, pp.213-243, 2012. ,
The Causes of Food Waste in the Supplier-Retailer Interface: Evidences from the UK and Spain, Resour. Conserv. Recycl, vol.55, pp.648-658, 2011. ,
Building Theories from Case Study Research. Acad, Manag. Rev, vol.14, pp.532-550, 1989. ,
