Condition-based maintenance of machines using hidden Markov models, Mechanical Systems and Signal Processing, vol.14, issue.4, pp.597-612, 2000. ,
Modeling of Failure Prediction Bayesian Network with Divide-and-Conquer Principle, Mathematical Problems in Engineering, pp.1-8, 2014. ,
Watchdog Agent-an infotronics-based prognostics approach for product performance degradation assessment and prediction, Advanced Engineering Informatics, vol.17, issue.3, pp.109-125, 2003. ,
Hidden semi-Markov model-based methodology for multi-sensor equipment health diagnosis and prognosis, European Journal of Operational Research, vol.178, issue.3, pp.858-878, 2007. ,
B: Fault diagnosis of power transformer based on support vector machine with genetic algorithm, Expert Systems with Applications, vol.36, issue.8, pp.11352-11357, 2009. ,
Gas turbine performance prognostic for condition-based maintenance, Applied energy, vol.86, issue.10, pp.2152-2161, 2009. ,
Development of intelligent fault diagnostic system for mechanical element of wind power generator, Journal of Korean Institute of Intelligent Systems, vol.24, issue.1, pp.78-83, 2014. ,
Fault diagnosis of monoblock centrifugal pump using SVM. Engineering Science and Technology, an International Journal, vol.17, issue.3, pp.152-157, 2014. ,
Fault diagnosis of centrifugal pump using symptom parameters in frequency domain, The CGIR Journal, vol.9, pp.1-14, 2007. ,
An intelligent chiller fault detection and diagnosis methodology using Bayesian belief network, Energy and Buildings, vol.57, pp.278-288, 2013. ,
