A Thesaurus-Guided Method for Smart Manufacturing Diagnostics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Farhad Ameri
  • Fonction : Auteur
  • PersonId : 944847
Reid Yoder
  • Fonction : Auteur
  • PersonId : 1061592
The unstructured historical data available in the databases of Computerized Maintenance Management Systems represents a wealth of diagnostic knowledge. In this paper, a methodology for converting the maintenance log data into formal knowledge graphs is presented. The methodology uses text analytics techniques, in combination with human-assisted thesaurus development methods, for generating a formal thesaurus, or knowledge graph, that encodes the semantic relationships between multiple maintenance entities. The knowledge graph proposed in this work uses Simple Knowledge Organization System (SKOS) standard. A java-based tool is developed that uses the generated knowledge graph as the input and conducts light-weight reasoning to support smart maintenance diagnosis.
489100_1_En_88_Chapter.pdf (174.91 Ko) Télécharger le fichier
hal-02419266 , version 1 (19-12-2019)
Paternité
Farhad Ameri, Reid Yoder. A Thesaurus-Guided Method for Smart Manufacturing Diagnostics. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2019, Austin, TX, United States. pp.722-729, ⟨10.1007/978-3-030-30000-5_88⟩. ⟨hal-02419266⟩
90 Consultations
43 Téléchargements
