Linearly implicit all Mach number shock capturing schemes for the Euler equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2019
We propose a family of simple second order accurate schemes for the numerical solution of Euler equation of gas dynamics that are (linearly) implicit in the acoustic waves, eliminating the acoustic CFL restriction on the time step. The general idea is that explicit differential operators in space relative to convective or material speeds are discretized by upwind schemes or local Lax-Friedrics fluxes and the linear implicit operators, pertaining to acoustic waves, are discretized by central differences. We have compared the results of such schemes on a series of one-dimensional test problems including classical shock tube configurations. Also we have considered low-Mach number acoustic wave propagation tests as well as nozzle flows in various Mach regimes. The results show that these schemes do not introduce excessive numerical dis-sipation at low Mach number providing an accurate solution in such regimes. They perform reasonably well also when the Mach number are not too small.
article-29-6-18.pdf (991.03 Ko) Télécharger le fichier
hal-02419411 , version 1 (19-12-2019)
Stavros Avgerinos, Florian Bernard, Angelo Iollo, Giovanni Russo. Linearly implicit all Mach number shock capturing schemes for the Euler equations. Journal of Computational Physics, 2019, ⟨10.1016/j.jcp.2019.04.020⟩. ⟨hal-02419411⟩
60 Consultations
372 Téléchargements
