Implicit-explicit rungekutta methods for time-dependent partial differential equations, Applied Numerical Mathematics, vol.25, issue.2, pp.151-167, 1997. ,
All mach number second order semi-implicit scheme for the euler equations of gasdynamics, 2017. ,
High order semiimplicit schemes for time dependent partial differential equations, Journal of Scientific Computing, pp.1-27, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-00983924
Hyperbolic conservation laws with stiff relaxation terms and entropy, Communications on Pure and Applied Mathematics, vol.47, issue.6, pp.787-830, 1994. ,
Large time step positivity-preserving method for multiphase flows, Hyperbolic Problems: Theory, Numerics, Applications, pp.849-856, 2008. ,
Entropysatisfying relaxation method with large time-steps for euler ibvps, Mathematics of Computation, vol.79, issue.271, pp.1493-1533, 2010. ,
Local time stepping with adaptive time step control for a two-phase fluid system, ESAIM: Proceedings, vol.29, pp.73-88, 2009. ,
Local time stepping applied to implicit-explicit methods for hyperbolic systems, Multiscale Modeling & Simulation, vol.8, issue.2, pp.540-570, 2010. ,
Multiresolution technique and explicit-implicit scheme for multicomponent flows, Journal of Numerical Mathematics jnma, vol.14, issue.3, pp.187-216, 2006. ,
An asymptoticpreserving all-speed scheme for the euler and navier-stokes equations, Journal of Computational Physics, vol.231, issue.17, pp.5685-5704, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00614662
Measurements of the speed of sound in air-water flows, Chemical Engineering Journal, vol.66, issue.2, pp.131-135, 1997. ,
Mach-number uniform asymptotic-preserving gauge schemes for compressible flows, Bull. Inst. Math., Acad. Sin, vol.2, issue.4, pp.851-892, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00635618
All speed scheme for the low mach number limit of the isentropic euler equation, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00409851
Analysis of godunov type schemes applied to the compressible euler system at low mach number, Journal of Computational Physics, vol.229, issue.4, pp.978-1016, 2010. ,
Numerical Approximation of Hyperbolic Systems of Conservation Laws, 2014. ,
An all-speed asymptotic-preserving method for the isentropic euler and navier-stokes equations, Communications in Computational Physics, vol.12, issue.04, pp.955-980, 2012. ,
Solving Ordinary Differential Equations II. Stiff and Differential-Algebraic Problems. (2Nd Revised, Springer Series in Comput. Mathematics, vol.14, 1996. ,
Semi-implicit method for three-dimensional resistive magnetohydrodynamic simulation of fusion plasmas, Nuclear Science and Engineering, vol.92, issue.1, pp.119-125, 1986. ,
A fully second order implicit/explicit time integration technique for hydrodynamics plus nonlinear heat conduction problems, Journal of Computational Physics, vol.229, issue.9, pp.3237-3249, 2010. ,
A second order self-consistent imex method for radiation hydrodynamics, Journal of Computational Physics, vol.229, issue.22, pp.8313-8332, 2010. ,
A second order primitive preconditioner for solving all speed multi-phase flows, Journal of computational physics, vol.209, issue.2, pp.477-503, 2005. ,
Singular limits of quasilinear hyperbolic systems with large parameters and the incompressible limit of compressible fluids, Communications on Pure and Applied Mathematics, vol.34, issue.4, pp.481-524, 1981. ,
Compressible and incompressible fluids, Communications on Pure and Applied Mathematics, vol.35, issue.5, pp.629-651, 1982. ,
Semi-implicit extension of a godunov-type scheme based on low mach number asymptotics. i: One-dimensional flow, J. Comput. Phys, vol.121, issue.2, pp.213-237, 1995. ,
A method for avoiding the acoustic time step restriction in compressible flow, Journal of Computational Physics, vol.228, issue.11, pp.4146-4161, 2009. ,
Finite volume methods for hyperbolic problems, vol.31, 2002. ,
A new numerical solver for flows at various mach numbers, Astronomy & Astrophysics, vol.576, p.50, 2015. ,
New numerical solver for flows at various mach numbers, A&A, vol.576, p.50, 2015. ,
The extension of incompressible flow solvers to the weakly compressible regime, Computers & Fluids, vol.32, issue.2, pp.173-196, 2003. ,
An asymptotic preserving all mach number scheme for the euler equations of gas dynamics, 2012. ,
Maestro: An adaptive low mach number hydrodynamics algorithm for stellar flows, The Astrophysical Journal Supplement Series, vol.188, issue.2, p.358, 2010. ,
Upwind difference schemes for hyperbolic systems of conservation laws. Mathematics of Computation, 1982. ,
Implicit-explicit runge-kutta schemes and applications to hyperbolic systems with relaxation, Journal of Scientific computing, vol.25, issue.1-2, pp.129-155, 2005. ,
Multiple pressure variables methods for fluid flow at all mach numbers. International journal for numerical methods in fluids, vol.49, pp.905-931, 2005. ,
High order well balanced schemes for systems of balance laws, Hyperbolic problems: theory, numerics and applications, vol.67, pp.919-928, 2009. ,
High order well-balanced schemes based on numerical reconstruction of the equilibrium variables, Waves and Stability in Continuous Media, vol.1, pp.230-241, 2010. ,
, The Dynamics and Thermodynamics of Compressible Fluid Flow, 1953.
Essentially non-oscillatory and weighted essentially nonoscillatory schemes for hyperbolic conservation laws, Advanced numerical approximation of nonlinear hyperbolic equations, pp.325-432, 1998. ,
Riemann solvers and numerical methods for fluid dynamics: a practical introduction, 2009. ,
Preconditioned methods for solving the incompressible and low speed compressible equations, Journal of computational physics, vol.72, issue.2, pp.277-298, 1987. ,
A conservative pressurecorrection method for flow at all speeds, Computers & Fluids, vol.32, issue.8, pp.1113-1132, 2003. ,
Implicit Upwind Schemes for Low Mach Number Compressible Flows, INRIA, 1997. ,
URL : https://hal.archives-ouvertes.fr/inria-00073607
